Control 24 fader issue.
Hello,
I have checked through the entire forum for an answer (sorry if I missed it), and I am sure it's just a button that is enabled or disabled, but when using the control 24 faders during mixing of a Pro Tools session, some faders will move when I touch them (this is what I want), and some are stuck in position. If I go into Pro Tools via the mouse, and move the fader in Pro Tools, the fader on the Control 24 does move to the position within Pro Tools. If I go back to the 24, the fader won't budge at all. Is this a setting that I have enabled or disabled? Any help would TRULY appreciated. Thanks so much. |
Re: Control 24 fader issue.
You might first go to peripherals and hunt for the control 24 via ethernet hunt and reestablish a sound connection with the board. If that doesn't work, try the old pref trash and database go way. Use the linke here :www.jcdeshaies.com and see if that helps. You'll have to hunt for the board again in peripherals but what the heck? |
I did forget to mention that I am using Pro Tools 7.4 LE on a pc, not a mac, and it's interfaced with a 002R. |
Sorry to say that I don't know a lot about the rest of your setup but my gut feeling is that it has nothing to do with your problem. This is a communication problem or a corruption at some level. You should (I hope) be back in the black soon! Best of luck!!!
Control 24 Fader Issue | youngas75 | ICON & C|24 | 19 | 06-25-2015 01:39 AM |
Scribble strips issue D-Control Fader Pack | kptkarl | ICON & C|24 | 0 | 01-13-2014 09:31 AM |
Fader Control issue | Sonic Blue Meanie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 08-21-2012 08:33 PM |
'Fader Pack' and ProControl Fader order issue | Ciaran | ProControl, Control|24, Command|8 | 2 | 03-21-2005 11:58 PM |
Control Surface - Behringer B Control Fader BCF200 | ironfin | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-14-2005 10:19 PM |
