  #241
Old 09-26-2019, 02:58 PM
Oliver M Oliver M is offline
Default Re: Automation AppleScripts for Pro Tools (Mac)
Originally Posted by echoesoflife View Post
Works like a charm, thanks kindly!
I am going to finish the script into a little app where you could select Online/Offline Bounce, Bounce location and select a few projects to bounce.
Once I am done, I will share the source code and the app here.
I am looking forward to this.
  #242
Old 10-01-2019, 04:02 PM
echoesoflife echoesoflife is offline
Hi all,
Making some progress, the script even works for multiple files selected in Automator (surprisingly!) - with a little bit of my help though.
There is one challenge which I couldn't solve yet, and this is regarding dialog windows.
For example, while PT is loading, it may pop up a dialog suggesting that my HUI controller is absent, and the OK button is required to proceed.
I am wondering if any of you have had some luck automatically detecting and pressing "OK", "No" or "Don't Save" buttons in the pop-up dialog windows in Pro Tools.
These windows always go with "window 1" identifier, however once I try to talk to button "OK" of window 1, the script refuses to do so.
Partially this may be because one has to wait until these windows appear, and I don't quite know how to achieve that. I tried repeat until window 1 exists, and this didn't work either.
Any help would be greatly appreciated.
Thanks,
Michael
Pro Tools 2019, Hackintosh High Sierra
  #243
Old 10-03-2019, 02:13 AM
clancychris clancychris is offline
Hey all!
I'm pretty new to Applescript (2 days lol) but I'm slowly working out how to do things. I'm trying to script a macro which I can use for recalling track templates for updating multiple sessions, reamping multiple sessions etc. I'm stuck at one point...
I need to open the pop up menu on a defined track name, hit recall preset and select the one I want.
I've managed to navigate to the correct track, I can mute, solo and set to record so I'm halfway there. I've identified the pop up button name etc and I can get it to hit any of these buttons without an issue:
Code:
    pop up button "Playlist selector"
    button "Track Record Enable"
    button "TrackInput Monitor"
    button "Solo"
    button "Mute"
    pop up button "Track View selector"
    pop up button "Automation Mode selector"
    pop up button "Track options"
The button I cannot get to work comes up in UIElementInspector as
Code:
pop up button "Track name
        \"Rhythm L\""
Code:
activate application "Pro Tools"
tell application "System Events"
	# Get the frontmost app's *process* object.
	set frontAppProcess to first application process whose frontmost is true
end tell
# Tell the *process* to count its windows and return its front window's name.
tell frontAppProcess
	if (count of windows) > 0 then
		set window_name to name of front window
	end if
end tell
tell application "System Events" to tell process "Pro Tools"
	click pop up button "Track name \"Rhythm L\"" of group "Rhythm L - Audio Track " of window window_name
end tell
When I run the script it says "expected end of line but found identifier"
I'm just so new to this that I've hit a roadblock.
  #244
Old 10-04-2019, 02:17 AM
Originally Posted by clancychris View Post
Hey all!
Code:
    button "Solo"
    button "Mute"
Code:
        \"Rhythm L\""
Code:
end tell
	end if
end tell
end tell
Hi Chris,
click the button by its index but by its name:
Code:
click pop up button 1 of group "Rhythm L - Audio Track " of window window_name
  #245
Old 10-06-2019, 02:04 PM
Hi all,
Thanks,
Michael
Look Michael, it is really hard to help if you keep asking questions without explaining in detail what you are after. I have the feeling you want us to complete your code for free only.
You haven't explained what the uiScript does, now you bring Automator stuff in. I have coded stuff for Automator and believe its a nightmare to deal with as its slow like hell. Thus I suggest to avoid it.
You need to explain in detail what you are trying to achieve, step by step. Only then you can expect decent help.
Things like checking for a window to appear has been discussed many times within this thread. Maybe you should start reading it. 😉
No harm intended.
  #246
Old 10-06-2019, 05:32 PM
No harm intended.
Hello Oliver,
Apologies for the ambiguous answer and description of the problem.
Most certainly not looking for anyone to complete my code for free. Firstly, I am new to programming on AppleScript, hence I am asking for help once I hit a roadblock. I have exhaustively googled the problem that I'm facing and was unable to find any definitive or helpful information.
Secondly, I have searched this thread for the answers (not exhaustively) and implemented some of the solutions regarding the pop up windows with no positive outcome. I have also implemented a few of the solutions (regarding file input, etc.) with positive outcome after hard trial and error, for which I am grateful.
If I am going overboard with requesting this advice, I would happily compensate for one's time. I was actually considering hiring programming services when I started this project.
Hence kindly let me know, and subsequent arrangements will be made with pleasure.
Otherwise here is the description of the complete workflow and the Script that fails to close the pop-up windows (next separate forum message).
  #247
Old 10-06-2019, 05:37 PM
1. Automator. Select the desired Pro Tools Project by using Get Specified Finder Items.
2. Automator. Get Value of Variable.
3. Automator. Run Apple Script (pass the input as arguments).
The following code works properly and does not contain any safety measurements to prevent pop up windows from interrupting the process:
Code:
property cliclickCLIPath : missing value
property shortDelay : 0.1
property medDelay : 0.3
on run {input, parameters}
	set cliclickCLIPath to "usr/local/bin/cliclick"
	set SelectedItems to input
			try
				repeat with x from 1 to count of SelectedItems -- the loop through all selected items
					set theFile to item x of SelectedItems
					tell application "Pro Tools" to open theFile
					set frontmost to true
					-- Open Memory Locations window if it is not open already
					if not (exists window "Memory Locations") then
						click menu item "Memory Locations" of menu "Window" of menu bar item "Window" of menu bar 1
						repeat until exists window "Memory Locations"
							delay shortDelay
						end repeat
					end if
					-- Set variable for Memory Locations window
					set mlWindow to (1st window whose name contains "Memory Locations")
					delay shortDelay
					tell mlWindow
						try
							my cliClick("c:400,400")
							-- click "Start"
							repeat with aRow in row of table "Memory Locations"
								if name of static text of UI element 2 of aRow starts with "Start" then
									tell static text "Start" of UI element 2 of aRow
										set {xPosition, yPosition} to position
										set {xSize, ySize} to size
										my cliClick("c:" & xPosition + (xSize div 2) & "," & yPosition + (ySize div 2))
									end tell
								end if
							end repeat
							-- click "End"
								if name of static text of UI element 2 of aRow starts with "End" then
									tell static text "End" of UI element 2 of aRow
										key down {shift}
										key up {shift}
									end tell
								end if
							end repeat
						on error e number n
							tell application "Pro Tools" to display alert "An Error Occurred" message e & " (" & n & ")" buttons {"Cancel"} default button 1
						end try
					end tell
					-- Press ⌥⌘B
					tell application "System Events" to key code 11 using {option down, command down}
					-- Press "Bounce"
							try
								-- HERE TO ADD ALL THE VARIABLES
								click button "Bounce" of window 1
								if exists (button whose name contains "OK") then
									click button "OK" of window "MP3"
								end if
							end try
						end tell
					end tell
				end repeat
			end try
		end tell
	end tell
	return input
end run
on cliClick(process)
	do shell script quoted form of cliclickCLIPath & " -r " & process
end cliClick
Next I am trying to add the safety elements which would close the window prompting to save the bounced project, as well as the windows which appear while the project is loading: HUI controller is missing, some I/O are missing.
The beginning of the code:
Code:
				--		activate application "Pro Tools"
				-- Don't Save Button
				if exists window 1 then
					click button "Don't Save"
					end if
				--SAFETY
				repeat
					if exists window 1 of application "Pro Tools" then exit repeat
					delay 0.5
				end repeat
				if name of static text of window 1 starts with "The original MIDI device" then
					tell button "OK" of window 1 of application "Pro Tools"
					end tell
				end if
				if name of window 1 starts with "Session Notes" then
					tell button "No" of window 1 of application "Pro Tools"
					end tell
				end if
				if name of window 1 starts with "Missing Files" then
					end tell
				end if
			end repeat
As far as I understand, the problem is that the script is not trying to continuously detect the pop-up windows, and/or not able to detect the windows before the project has loaded and the main PT window has appeared.
As a result, the required buttons are simply not clicked. If I manually click them, the script continues to bounce just fine.
Any pointers would be greatly appreciated. If this is outside of the normal scope for the discussion, kindly send me a PM to discuss this further.
Thank you,
Michael
  #248
Old 10-07-2019, 07:56 AM
Hi Chris,
Code:
Thank you so much! I've been tearing my hair out until now lol
  #249
Old 10-11-2019, 08:46 AM
Code:
			try
							delay shortDelay
						end repeat
					end if
					delay shortDelay
					tell mlWindow
						try
							-- click "Start"
									end tell
								end if
							end repeat
							-- click "End"
										key down {shift}
										key up {shift}
									end tell
								end if
							end repeat
						on error e number n
						end try
					end tell
					-- Press ⌥⌘B
					-- Press "Bounce"
							try
								end if
							end try
						end tell
					end tell
				end repeat
			end try
		end tell
	end tell
	return input
end run
end cliClick
Code:
					end if
				--SAFETY
				repeat
					delay 0.5
				end repeat
					end tell
				end if
					end tell
				end if
					end tell
				end if
			end repeat
Thank you,
Michael
The 1st part of your code is pretty much my code.
But it is just a small part of the entire script, right?
A couple of hints:
Instead of dealing with windows you should prepare your session so that no windows pop up. Checking for open windows and /or pop ups can make a script become real complicated and unstable. Especially because some windows in PT have no name (hint to Avid: Give all PT windows a decent name!!).
But if you really want to go this route then you'll have to add a window counter function which counts windows all the time while the script runs.
This can become really complicated depending on how much windows you wanna watch this way.
IMHO, I'd work with perfectly prepared copies of the sessions and let PT just save the session at the end so that you avoid at least that one dialog window which will eventually always show up after a bounce.
Honestly I am not sure why you have to deal with all the other windows, missing files etc. Just work with a session copy that actually works!
Thats it from me really, because since you still refrain from posting the full script, I cannot help any further, sorry.
Last edited by Oliver M; 10-12-2019 at 04:57 PM. Reason: The smiley in my post was displayed as a ��.s
  #250
Old 10-11-2019, 03:39 PM
Thanks Oliver, duly noted. This makes sense. I will implement these ideas and will report back. Thanks again.
Pro Tools 12 Trim Automation [email protected] Pro Tools 12 2 08-16-2015 04:25 AM
Pro Tools 11.2.1 Automation Bug?! Gneal550 Pro Tools 11 1 11-22-2014 01:15 PM
GRM tools automation bug? D'Animation Pro Tools TDM Systems (Mac) 6 10-08-2014 08:21 AM
scripting Pro Tools; automation Bermaster 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 12 10-01-2004 12:38 PM
AppleScripts and other Macros for PT Bergeron Tips & Tricks 1 11-15-1999 06:55 PM
