Re: HD|N and system sounds...
Hello I am in the same situation with an I7 3930k +hd native+192I/o and dangerous monitor source
If I want to listen any cd or wave sound from my I7 its better to use the motherboard soundcard spdif output from my I7 to the dangerous monitor or the hd native driver and use the spdif output from my 192to the dangerous monitor sourceThks |
pro-tools-pc.com TRASHER Pro Tools Utility(updated 4-11-2024) HD Native, Avid 16x16, Eleven Rack, Focusrite Clarett 8preX, UA Quad Apollo TB. Intel I7 9900k Win 10 |
Ok the sound would be better with my mb spdif output to the dangerous?
Cause 192 output spdif got better converter? Thks |
there are no working drivers for the HDN for system sounds. have no option but to use your mb audio out.
Alternatively use an ASIO device and patch that back in.
Aaron Mulqueen - 001 HD Native |
#16
The hdn is not like a digi 003 with digi drivers working with Intel?
Before I was with my digi 003 under windows xp pro and I could listen any sounds from my Intel through the digi 003 factory Actually I got the pro tools hd native with a 192 analog + digital card and a dangerous monitor source for monitoring and what would be the best solution to listen my cd and waves with my Intel? Really spdif mb output to the dangerous spdif input? And not possible with the hdn through the 192 cause no working drivers? Regards |
#17
#18
Is running spdif out to Omni still a no go? Tried it and got a signal from MB into the Omni (channels 5-6), but couldn't get that signal to come out the monitors.
Is that a "driver issue?"
Pro Tools 12.4 HDN, PCIe, Omni & Digi 192 ASUS Sabertooth, Intel i7 3820 3.6Ghz 32 GB 1600Mhz Corsair RAM SSD 500GB Samsung WIN 10 64bit |
HD|N and system sounds... | danander11 | Pro Tools HDX & HD Native Systems (Mac) | 0 | 10-28-2012 05:24 AM |
Pro TOols playback is OK, system sounds and other sounds won't play | bimple | Windows | 1 | 08-24-2011 05:14 PM |
System sounds & MBox | robbins876 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 03-22-2003 12:00 AM |
mix sounds different on a hi-fi system | ChenteleyA | Tips & Tricks | 10 | 02-06-2003 10:23 AM |
System sounds through 001? | Rich_L | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-13-2000 09:26 PM |
