C24 with 192 I/O output help
Hello all,
I've got a C24 and a 192, and I'm not getting any output when I use ProTools 8. It will play and the counter and meters will respond on the C24. It is also able to control PT fine. I have a DB25 running from the Analog Out card on the 192 to the Pro Tools In on the C24. I have a DB25 to XLR running from the Control Room Out on the C24 to my Genelec Sub/Distributor. In PT, the output from the 192 is set as: Angl 1-2 is L, C. 3-4 is R, Ls. 5-6 is Rs, LFE. Each of these XLR connectors is connected properly to the sub. I've tried different montoring modes, turned volumes up all the way, etc. I'm stumped at this point so any help would be much appreciated. thanks, BJ |
Re: C24 with 192 I/O output help
Check peripherals > ethernet for the C/24 connection.
(Although the monitor section is analog and should work regardless.) Run some pink noise or tones for calibration and verification. C/24 monitor switch in main, no mute etc..... In pre fader metering do you see meters? Reset the C/24 from it's utilities (Tools)? When I put (Installed) PT's 8 the C/24's firmware was updated (Prompted). C/24 PT8HD, 2-192's expanded, G5 Dual 2.7, OS 10.5.5 All working great. Although I just found the Track punch features needs to have the channels record light flash when punched out. You currently have no way of knowing unless your computers monitor is up. |
No output device selected in Studio Monitor Express, using Default Output (Mbox Pro). | Focuret | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 02-12-2014 07:33 AM |
Fast track pro: signal on output 2 while output level at 0 | sbrunot | FireWire & USB Audio Interfaces (Mac) | 1 | 12-26-2013 04:11 PM |
Whats the Difference between Bounce to Disk Source -> Physical Output vs -> Output | Epik Productions | Pro Tools TDM Systems (Mac) | 8 | 05-03-2013 12:48 PM |
Eleven Rack: Headphone Output Impedance & Amp Output Tech Specs | MR290378 | Eleven Rack | 12 | 11-29-2011 05:10 PM |
No output to 1622 *and* master fader shows output? | nettwerk | Pro Tools TDM Systems (Mac) | 1 | 10-30-2000 05:35 AM |
