Old 06-05-2012, 03:53 PM
moofie moofie is offline
Default 10.2 Glide Automation Behaviour
Morning All,
Posting this here as well as this may be an issue more obvious to the Post guys ...
Very quickly, as I'm in the middle of a predub, but has anyone noticed a change in the behaviour of Glide to Current or Glide to All Enabled since the introduction of 10.2?
Appreciate any/all comments.
Cheers
Tom
Dubber: Mac Studio M1 Ultra, Ventura 13.1, 64 GB RAM, PT Ultimate 2022.12, HDX 1, Sync HD, HD I/O x 2, HD MADI x 1, Black Magic UltraStudio HD Mini, Satellite Link. Source 1 Rig: Mac Studio M1 Ultra, Ventura 13.1, 64 GB RAM, PT Ultimate 2022.12, HDX 3, Sync HD, HD MADI x 1, Satellite Link. Source 2 Rig: 2 x 3.46 6-Core Intel, 10.13.6, 64gb RAM, PT Ultimate 2019.10, HDX 1, Sync HD, HD I/O x 1, HD MADI x 1, Satellite Link. SSL X-8 MADI Router. Dolby CP750 Cinema Processor. 2 x D-Control ES (Dual Operator). Colin Broad PD-1. Colin Broad TMC-1
Old 07-20-2012, 10:43 AM
reichman's Avatar
reichman reichman is offline
Default Re: 10.2 Glide Automation Behaviour
Yes! WTF? Today's the first day I've really needed the glide function since moving to 10.2, and it's changed.
It seems like it's gliding before the selection, earlier until the next automation nodes, instead of the old behavior within the selection. This is making it very hard to use. Is this an intentional change on Avid's part?
Old 07-20-2012, 10:48 AM
reichman's Avatar
from the manual:
Glide Automation Considerations
When Glide Automation is applied to automa- tion data, it behaves as follows:
• When a selection is made, automation break- points are written at the start and end points of the Glide Automation. The automation value at the start of the selection is the start point of the Glide Automation and the end of the selection is the end point of the Glide Au- tomation. The Glide Automation that is cre- ated between the two is based on the length of the selection and the end value that is se- lected.
• If automation breakpoints follow the selec- tion, they are not changed, but the value se- lected for the end of the selection is written from the end point up until the next break- point.
it's broken in 10.2. this doesn't make sense.
Old 07-22-2012, 09:44 PM
cjguitar cjguitar is offline
Yes, it has changed and has been reported to Avid. Should hopefully be fixed soon.
Chris M. Jacobson, CAS
Re-recording Mixer, Sound Designer
IMDB
Old 07-23-2012, 01:33 PM
Whew, thought I was going bonkers.
I use Glide everyday (especially to get in/out of NR automation controlling the DNS3000 h/w)...proving interesting finding subtle work arounds for a work practice you've used for years.
Onwards!
Old 07-23-2012, 01:53 PM
reichman's Avatar
FWIW, this is the only major problem I have with 10.2. Stability and reliability are absolutely terrific.
Old 07-23-2012, 02:26 PM
The golfer The golfer is offline
What about clip gain? I heard converting clip gain back to automation moves the regions. I am waiting to upgrade to 10.2 just because of this tinny bug...
Serge Hamel
Mixer / Sound Designer
http://www.netpostproduction.com
http://immersivesoundvr.com/
Old 07-23-2012, 03:06 PM
Agreed!
Old 07-23-2012, 06:43 PM
Onwards!
A couple of workarounds I found that work well for me:
1. Use "Cut Special>All Automation" over area you want to glide. Or, 2. Switch to an automation view (volume for instance) and use Control+X to cut all automation and it will glide the automation the length of the selection before the cut.
IMDB
Old 07-23-2012, 10:04 PM
Nice Chris, appreciate the angle!
Cheers
Tom
HTML code is On
Glide Automation bug in PT 10.3.4 mgoorevich Pro Tools 10 19 03-17-2013 09:09 AM
Glide Automation still not working? soundarchitect macOS 1 01-08-2013 11:17 AM
10.2 Glide Automation Behaviour moofie macOS 0 06-05-2012 03:24 PM
glide automation still works? tomcat Pro Tools TDM Systems (Mac) 5 01-27-2008 05:13 PM
D-Command, Preview, Glide automation Redhouse_Janke ICON & C|24 0 12-13-2007 07:04 AM
