High Sierra
OS X is the old name for macOS. You download macOS from the Mac App Store. Apple normally gives access to old versions of OS X and macOS in the Mac App store if you have downloaded them before (when they were current), otherwise it is only the currently release (which is High Sierra). You can Apple contact support and try to ask for access to older versions if you really need it. Or wait until stuff is supported or known to work well enough (which may be now) and upgrade to High Sierra or use a recovery partition to reinstall.... or.... all depends on what you are trying to do and why.
None of this is Pro Tools specific, you should be able to Google and find out all you need on getting macOS or OS X installers. Sent from my iPhone using Tapatalk |
Re: High Sierra
El Capitan is the last OS available on the "purchased" tab... While High Sierra can be of course downloaded from the App Store, here's the link for Sierra (go to "Get Sierra from the App Store": https://support.apple.com/en-us/HT208202
Mac Pro 5,1 (Mid-2012) 12-core 2 x 3.3 GHz / MSI RX 560 / 40GB ram / macOS 10.14.5 / Pro Tools 2019.5 / Logic Pro X 10.4.4 Arturia Keylab 88 • Presonus Faderport 8 • MOTU 896 • iPad Air 2 w/ PT Control NI Komplete Ultimate 11 • Albion One • Soundiron Choirs • Pianoteq • Analog Lab • VSL SE/Chamber Strings • etc |
Re: High Sierra
* Macbook Air : M1 ~ 16gb ~ 1tb ~ Ventura latest * Hackintosh : i9-9900k ~ 16gb ~ 3tb ~ Monterey 12.6.1 * PT 23.6 + Ableton Suite 11.3 * Soundtoys + Valhalla + Fabfilter + Spitfire * RME Fireface UCX II ~ Arturia Keylab Essential 49 * various clarinets, trumpets, flutes, plucky stringy thingies |
Re: High Sierra
Yeah it's pretty doubtful that sierra will be given drivers for the new iMac pro in an update... Also, I'm sure high sierra is technically working with PT 12 I am more worried about the combination of a whole new computer with all new drivers and components AND a new operating system. Sounds like way too much of a headache for me. I'll just wait a few months and see if they come out with a new mac pro.
Re: High Sierra
PT 12.8.1 and 12.8.2 crash consistently after 20-30 min of use on High sierra for me. Is that expected or happening to others?
Re: High Sierra
With that kind of general behavior one thing to suspect is plugin memory leaks. What does the macOS Activity Monitor show you for memory usage? esp. the the memory pressure graph? Does it keep getting worse as you use Pro Tools? Try removing all plugins from the plugin folder and trashing prefs and restarting Pro Tools, etc. |
Re: High Sierra
However I've seen that can get problematic with particular plug ins (SSL Duende for example) or other DAWs (Logic 10.3.3) on the same system. Pro Tools itself is working well here. As yet. Cheers. |
Re: High Sierra
Pro tools 12.8.2 on High Sierra working without problems here. Pretty solid I may say.
My first post here. Hello to all! |
Re: High Sierra
Avid updated the Pro Tools compatibility document and Pro Tools 12.8.3 is compatible with High Sierra
http://avid.force.com/pkb/articles/e...3-High-Sierra/ Pro Tools macOS 10.13 (High Sierra) is supported with Pro Tools 12.8.3 and higher (macOS 10.13.2 required). Note that there was no Pro Tools First 12.8.3 release). |
Re: High Sierra
But it seems 12.8.3 is not available to download yet...
Digi003 with High Sierra | elmodagansta | FireWire & USB Audio Interfaces (Mac) | 22 | 04-18-2020 10:35 PM |
S6L AVB with OS X High Sierra | brinnbacka | VENUE Live Sound Systems | 3 | 10-20-2018 12:52 AM |
High Sierra | jon9 | Eleven Rack | 0 | 11-16-2017 03:35 AM |
High Sierra yet? | mlavin00 | Pro Tools 12 | 18 | 11-13-2017 10:09 AM |
12.8.2R2 on High Sierra | TrentWilliams | Pro Tools 12 | 3 | 10-21-2017 10:09 PM |
