  #31
Old 04-13-2020, 06:28 AM
maalesh maalesh is offline
Default Re: Eleven Rack Compatibility with MacOS Catalina
The editor and driver were working just fine on Catalina until yesterday when I got that "cannot initialize midi engine" error message. So now I'm running it on a Parallels / Windows 7 virtual machine within Catalina.
  #32
Old 05-21-2020, 08:49 PM
ac30fan ac30fan is offline
Just curious - had you recently updated Catalina and/or PT?
2019 iMac 27" 5k Retina
3.6 Ghz 8-Core Intel Core i9
Mac OS 10.15.2 / 60GB RAM
UAD FW Apollo Duo (Thunderbolt Card)
PT 2019.12
Eleven Rack FW v2.00.1 / Software 1.2.13
  #33
Old 05-23-2020, 07:52 PM
Thossie Thossie is offline
So will Avid eventually support Catalina OS?
Any workarounds?
All I need is to get my MacBook to recognize my Eleven Rack for audio playback.
  #34
Old 05-24-2020, 10:49 AM
BCnSTL's Avatar
BCnSTL BCnSTL is offline
As I interpret AVID's 11R end-of-life statement they should update the drivers for Catalina. But will they? Who knows.
I love the 11R tones and integration with Pro Tools. It is central to my workflow. So much so I'm contemplating moving to Windows - or less disruptively - downgrading to Mojave.
The 11R 64-Bit Windows drivers work fine and should work for quite some time barring some major internal changes to the OS.
  #35
Old 05-25-2020, 06:21 AM
JoelG's Avatar
JoelG JoelG is offline
Just an FYI that the end of life is for replacement parts and service. They may not make an updated driver before that date, and they may update it after that date.
That said, it doesnt look too likely - opinion only..
Joel
Jame Space:
HP Elite 6300 / Core i5 3570 / 12GB RAM / Win 10 Pro
Pro Tools 2019.12 HD / Focusrite 18i20 + M-Audio ProFire 2626
Home:
Asus B450 Pro4 / Ryzen 5 2600 / 32GB RAM / Win 10 Pro / Pro Tools 2019.12 HD / Focusrite 18i20 + M-Audio ProFire 2626
Rig:
Eleven Rack / ART SLA1 / Fender Mustang V 412 / FCB1010 w/ EurekaPROM
  #36
Old 05-26-2020, 07:13 PM
ebeaty ebeaty is offline
I've been having issues with my 11R mainly with re-amping and recording. It's definitely due to Catalina because it worked fine with Mojave. The 11R Editor works fine, however.
My workaround is to use both Outputs to Amp L & R. One is set to "Amp Input" for the dry guitar/mic signal in 11R's User Settings. That feeds to one input channel of my audio interface. The other output is set to "Rig Output" for the entire rig sound, feeding to the other input channel of my audio interface.
Note: Make sure you don't have any 11R effects enabled on the dry signal. Try to keep it as dry as possible. You don't have to disable the Amp/Cab if you set that channel's output to "Amp Input," but you may still have to disable speaker resonance.
I've noticed Avid finally made some updates for Pro Tools and other software recently to help with Catalina compatibility, but no such luck for 11R. I also read somewhere else—it may have been this forum but, I don't remember—that the 11R is supposed to be supported until 2024. If nothing else, I'm glad there's a workaround.
macOS 10.15 (Catalina) and Avid Products Avid Technical Alerts 0 10-07-2019 11:11 AM
Eleven Rack compatibility options? needled39 Eleven Rack 3 10-02-2017 11:48 PM
Eleven Rack and Ubuntu with Ardour compatibility CeeJayTheFirst Eleven Rack 1 06-15-2015 01:33 PM
Eleven Rack compatibility problems? fastnboulbous Eleven Rack 0 03-24-2011 07:08 AM
Eleven Rack in system settings of MacOS clausiii Pro Tools M-Powered (Mac) 1 12-20-2009 07:15 AM
