#21
Re: BUG: Match alternates out of Sync to AAF
And btw, is there any way to fix this issue (maybe inside mediacomposer, maybe with a batch import of the corrected files?) other than manually fix the sync for every single region in pro tools? Davide |
#22
Other than that there is no way. Thing is: Once it's in the AVID the sync is already off if they use tc-slates or auto-sync. So the AAF won't be a sync reference anymore from the start. It's a huge dilemma. Chicken vs. Egg situation. Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron |
#23
Do you know a software that can batch truncate sound files to full frame? Anyway, I fear that's it's too late and we'll need to check the sync of the expanded Pro Tools audio tracks against the aaf and the picture. Davide |
#24
Question, since the sync is off in the AVID, when we use the Field Recorder workflow to assemble the poly files, are they actually correct for sync since they do not sync with the AAF tracks? |
#25
I may be wrong but below are my current conclusions on the subject.
As long as the Avid is running a full MXF project the audio files themselves will be in sync with the avid. That's what the "fillers" are for. And as long as the AAF is exported as a MXF AAF it will still be in sync when it gets into the daw. Now the only way to get the match alternates to stay in sync is to convert the AAF session to bwav before matching. But that will in turn remove some metadata that is stored in the MXF container. It's quite a mess. As stated earlier only some machines do not start recording on a frame edge, but if you don't sync up often enough it will still be off even with a cantar. But then it will get even worse in a way, because everything will look and work ok all through the chain, but in reality any drift between the cantar and the camera frame edge is likely to be ignored. Thus the auto or clapper synced audio even in the avid will be up to a frame out of sync. |
#26
But I doubt the cantar will drift a frame over a day, not so sure about all the different cameras though.
#27
This has nothing to do with subjective sync. The issue I mention is a technical thing that will always happen no matter how tight or lose your interlock between camera and sound recorder. It also has nothing to do with drift or any other sync-issues that might occur on top of what I've posted earlier. And even if there is drift the mentioned problem will be added on top. Fact is that certain machines (Deva, Sonosax, Fostex, Nagra and possibly more) do not time-stamp their files on full frames (or ideally 00-frames) which leads to this problem because on one side they use TC as an interlocking grid on the other side they do not time-stamp the files on the grid they are resolving to. IMO, for a machine made to sync to picture it makes no sense whatsoever to start a file in between frames. Imagine a multi-machine setup and all of them stamping their files at random in-points "somewhere close to the next frame boundary". The AVID however assumes that everything coming in is frame-accurate. This is the dilemma. What this leads to can be read in the earlier posting of this thread. This issue could be solved by the recorder mfg but some of them say that it's an AVID issue. Problem is that when you expand to track that there's another point where your files are pulled out of sync relative to the AAF. This is where it gets really confusing especially on shows that used multiple different recorders. I know that we can adjust sync manually and all of those arguments. The point is that within the whole chain there are now multiple stages where things change their sync reference randomly every time you swap out a leg of a recording that should be using the identical TC reference. Frank.
PTHDn 2024.3 (OSX13.6.5), 8x8x8, MacPro 14,8, AJA LHi, SYNC HD, all genlocked via AJA GEN10, 64GB RAM, Xilica Neutrino, Meyersound Acheron Last edited by Frank Kruse; 03-10-2014 at 07:02 AM. |
#28
If, as I suggest above, that the FRW without using Titan to phase is actually better sync, or possibly even actual sync, then I can now stop using Titan and move forward using the FRW and saving time and money. |
#29
Which is more sync the AAF or the conform needs to be thoroughly tested further. Which I can not do at the moment. But one thing's for sure. Things randomly change sync during this workflow because of a relatively small problem at a very early stage in the food-chain. Thing is: Neither the recordists nor we can fix the cause. It has to be done by AVID and/or the recorder manufacturers. I agree what you say about the FRW. It is a huge time-saver since it can conform an entire reel in just a few seconds without the downsides of EDLs based "Titaning". Over on JW the consensus seems to be "stop whining and fix it in post just like you did the last 50 years." "Sync is subjective." "By the time it's on TV it will be 5 frames off anyway." which I don't find overly satisfying as a "solution" I must say. and I think mostly said because the issue isn't really understood. Or like an editor I work with always says: "No solution, no problem". That seems to be the motto. There's really no reason why the FRW shouldn't be bang on down to a sample these days. Sorry, I don't have a recipie for you at the moment. No time for further tests at the moment but the cause is pretty clear. A combination of sound for picture recorders not time-stamping their files on the TC-grid and AVID MC shifting them because it assumes all incoming media is frame-accurate. Frank.
Alternates Match issue in PT 9 | nathanaelj83 | Pro Tools 9 | 0 | 10-10-2012 02:40 PM |
Alternates Match Doesn't Work - Screen Recording | nathanaelj83 | Pro Tools 10 | 0 | 10-10-2012 02:39 PM |
7.2 & 7.3 'field recorder" alternates. Any success | postprosound | Post - Surround - Video | 51 | 08-14-2012 03:46 PM |
Pro Tools 10 no CTPK matching Alternates | Matze1985 | Post - Surround - Video | 1 | 07-11-2012 12:52 PM |
matching alternates doesn't work in PT9? | tools | macOS | 3 | 09-07-2011 12:28 PM |
