MP 7.4 crashes during launch after \"Setting up MIDI\"
Not much success for me either, I'm not even able to start 7.4.
I first uninstalled 7.3.1cs5 (which worked fine), rebooted the PC, installed 7.4 and rebooted again. When I tried to start 7.4, it iterates the plugins successfully and starts DAE, but after that it crashes immediately after displaying "Setting up MIDI". I've tried uninstalling PTMP and all Digidesign-related files a few times, and I also downloaded the installer again in case it would have been corrupted but the files were identical. After getting completely frustrated I decided to install 7.3 (I had the installer still on my hard drive) and it started without problems. Has anyone else had any problems getting the 7.4 to start? |
Re: MP 7.4 crashes during launch after \"Setting up MIDI\"
Yes i have the same problem - crash duing launch after displaying "Setting up MIDI". Error in "msvcr80.dll".
I tried install PT 7.4 on fresh installation Win XP (full updated) - without avail. This advice doesn't work: http://www.digidesign.com/index.cfm?...0&itemid=18677 my config: PT LE 7.4 Win XP Home - Czech version (non english - maybe that's the snag) Digi 002 Rack P4 3,6 GHz, 3G RAM .... Any solution? |
I finally got 7.4 working, but I couldn't find the root cause of the original problem.
I created a new user account, tried starting PT from there and was completely surprised to see it starting normally. The problem still exists with my original user account (7.3.1cs5 and all previous versions down to 7.0 never had this problem). My system is a bit similar to yours, I also have a non-English version of Windows XP Home Edition (in my case Finnish). Also the user account name under which PT is crashing contains Scandinavian characters. I can't say whether the non-English characters cause the problem, because the new user account name doesn't contain any "weird" characters. Please try if creating a new user account helps in your case and post the result. |
Hello everyone,
i have the same problem, any of the solutions posted here did't help. I'm really p...ed off, looks like I'm another fool to waste 50 euros.. |
Thanks for your advice. I tried create new user account and run PT 7.4. Nothing. Still crash during launch after "Setting up MIDI".
I've never used this tool, but it probably won't do any more harm to try the Tech Support Utility: http://www.digidesign.com/index.cfm?...4&itemid=25974
Corrupted preferences are probably not the issue here since you already tried installing on a clean XP and it still didn't work. I think SiSoftware Sandra is the recommended way to get a full listing of the system configuration and installed software, instructions can be found here: http://duc.digidesign.com/showflat.p...part=1#1103324. Please post the Sandra information (both marwaq and ivo903), I could try to see if there's anything common with my system (I'll also try to find the differences between my working and non-working user accounts when I get back home). |
OK, in my case the problem really seems to be related to non-ASCII characters in the user account name. I created a couple of new user accounts and tested all existing ones. PTMP 7.4 works fine with all accounts with only ASCII characters in the name and crashes at the "Setting up MIDI" stage with every account containing non-ASCII characters (tried the Scandinavian characters "ä" and "ö").
I think, that in user account name problem isn´t only. My user account name is "Martin". Here is my sandra report: www.lightdesign.cz/Sandra_report.txt
Thanks for Your time. |
I can't find anything obviously wrong in the Sandra info, but I haven't really followed the compatibility discussions here so maybe someone who knows about these things could have a look.
There might be several reasons for crashing. In my system it seems to be related to non-ASCII characters but in your system it's probably something else. I guess it would be time for the Digidesign support to chime in, if they're reading this... |
Thanks for help!!! Here's mine...
System Host Name : PC User : Ivo Workgroup : SKUPINA Processor Model : AMD Athlon(TM) XP 2800+ Speed : 2.08GHz Model Number : 2800 (estimated) Cores per Processor : 1 Unit(s) Threads per Core : 1 Unit(s) Internal Data Cache : 64kB, Synchronous, Write-Back, 2-way set, 64 byte line size L2 On-board Cache : 512kB, ECC, Synchronous, Write-Back, 16-way set, 64 byte line size System System : System Manufacturer System Name Mainboard : ASUSTeK Computer INC. A7V600-X Bus(es) : AGP PCI IMB USB FireWire/1394 i2c/SMBus Multi-Processor (MP) Support : No Multi-Processor Advanced PIC (APIC) : Yes System BIOS : Award Software, Inc. ASUS A7V600-X ACPI BIOS Revision 1005 Total Memory : 1GB DDR-SDRAM Chipset 1 Model : ASUSTeK Computer Inc VT8377 Apollo KT400/A/600 CPU to PCI Bridge Front Side Bus Speed : 2x 167MHz (334MHz data rate) Total Memory : 1GB DDR-SDRAM Memory Bus Speed : 2x 167MHz (334MHz data rate) Video System Monitor/Panel : Monitor Plug and Play Adapter : NVIDIA GeForce FX 5200 Physical Storage Devices ST3120026A (ATA) : 112GB (C:) (D:) ST3200826A (ATA) : 186GB (F:) WD 5000AAJS Externa (FireWire/1394) : 466GB (G:) HL-DT-ST DVDRAM GSA-4120B (ATAPI) : N/A (E:) Logical Storage Devices Hard Disk (C:) : 20GB (8.9GB, 45% Free Space) (NTFS) @ ST3120026A (ATA) Dokumenty (D:) : 92GB (8.8GB, 10% Free Space) (NTFS) @ ST3120026A (ATA) Hard Disk (F:) : 186GB (83GB, 44% Free Space) (NTFS) @ ST3200826A (ATA) IVO (G:) : 345GB (156GB, 45% Free Space) (FAT32) @ WD 5000AAJS Externa (FireWire/1394) CD-ROM/DVD (E:) : N/A @ HL-DT-ST DVDRAM GSA-4120B (ATAPI) 3.5" 1.44MB (A:) : N/A Peripherals Serial/Parallel Port(s) : 1 COM / 1 LPT USB Controller/Hub : Universální hostitelský řadič VIA Rev 5 a vyšší USB USB Controller/Hub : Universální hostitelský řadič VIA Rev 5 a vyšší USB USB Controller/Hub : Universální hostitelský řadič VIA Rev 5 a vyšší USB USB Controller/Hub : Universální hostitelský řadič VIA Rev 5 a vyšší USB USB Controller/Hub : Řadič VIA USB Enhanced Host Controller USB Controller/Hub : Kořenový rozbočovač USB USB Controller/Hub : Kořenový rozbočovač USB USB Controller/Hub : Kořenový rozbočovač USB USB Controller/Hub : Kořenový rozbočovač USB USB Controller/Hub : Kořenový rozbočovač USB FireWire/1394 Controller/Hub : Hostitelský řadič IEEE 1394 dle standardu OHCI Keyboard : Standard 101/102-Key or Microsoft Natural PS/2 Keyboard Mouse : Myš Microsoft pro port PS/2 Here's Mine... MultiMedia Device(s) Device : Standardní game port Device : E-MU E-DSP Power Management Mains (AC) Line Status : On-Line Operating System(s) Windows System : Microsoft Windows XP (2002) Professional 5.01.2600 (Service Pack 2) Platform Compliance : Win32 x86 Network Services Adapter : VIA Compatible Fast Ethernet Adapter Performance Tips Warning 100 : Large memory sizes should be made of Registered/Buffered memory. Tip 2546 : Large memory modules should be ECC/Parity. Tip 2 : Double-click tip or press Enter while a tip is selected for more information about the tip. It looks like me and Marwaq both have Czech Win XP, that could be the problem..? I really appreciate your interest, i'm really desperate.. ivo |
Launch crashing at 'setting up midi' | paydoogs | Pro Tools SE and Essential (Win) | 1 | 10-21-2011 07:58 AM |
9.0.2 crashes when setting up MIDI peripherals? | tblythe.sound | macOS | 3 | 06-02-2011 09:38 AM |
Pro Tools Crashes setting up MIDI | products7074740 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-06-2009 07:11 AM |
7.4 LE Still Crashes when SETTING UP MIDI! Where R U?? | Ogun04 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 11-25-2007 02:22 PM |
Can not launch PT LE 7.4! Crashes when SETTING UP MIDI | Ogun04 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 11-15-2007 11:54 AM |
