Audio Suite plugin chain questions
I have been using the audio suite version of Slate's Virtual Tape Machine on each track to cut down on processing power. Since it's usually the first plugin in the chain this has been pretty easy, but on this particular mix I was given a very hot kick drum signal and had to run the trim plugin before VTM to lower the gain coming in to the VTM. If I want to apply AS VTM to the track and keep the trim level intact, do I need to process the audio suite trim before rendering the track with VTM? |
Re: Audio Suite plugin chain questions
Yes, otherwise it will process at a different level P.S. Why are you not using clip gain instead of the trim?? Chris
What's the advantage?
Audio Suite Chain | GS-DK | Pro Tools 10 | 6 | 12-19-2012 05:21 PM |
Audio Suite - Gain Plugin…..???? | YYR123 | Pro Tools 9 | 2 | 04-08-2012 08:51 PM |
Where to post for Media Composer's audio suite questions? | Joachim Claus | General Discussion | 2 | 08-07-2009 04:18 AM |
Auto Tune - Real Time or Audio Suite + Questions? | epu | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 08-03-2006 08:47 PM |
Audio Suite questions | dat_nomad | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 4 | 06-23-2003 08:23 PM |
