Replace Region BUG
hi,
in our PT HD 7.4.2 systems, running Leopard on Mac Pros, we have found a bug in the replace region functionality: it will not work on the first (top) track in a session (!). It works fine on any other track, just not the top one. Currently the workaround is to move the top track down, or create a new track and place it above, but it is rather annoying. Any chance of having this problem looked at? |
Re: Replace Region BUG
YES!
However i'm running 7.4cs6 on a Quad G5. This bug has been around since i think 7.x when they changed Replace region so you can't use it without the "Show Auto-Created Regions" switched on. The work around is pretty simple. Just drag your track down lower in the edit window. fman |
Replace region command in PT 7.1 | fman | Pro Tools TDM Systems (Mac) | 1 | 05-30-2006 09:45 AM |
Using Replace Region — need expert | Dan Pinder | Tips & Tricks | 9 | 12-16-2005 11:01 PM |
6.9 Mac Replace Region Bug?? | Borg | Pro Tools TDM Systems (Mac) | 7 | 07-05-2005 08:17 PM |
Region Replace | webby | Tips & Tricks | 4 | 06-09-2005 09:44 PM |
Replace all instances of a region | d_matt | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 1 | 12-15-2003 11:30 AM |
