How to import aiff Project files?
I've been given a job of mixing a Project that was recorded on an older Zoom Multi Track recorder.
I'm told they are AIFF Files. I tried importing them without success. Is there a way? Thanks I'm using, PT10, MacBook Pro, Presonus 16.4.2, Glyph Xternal HD's |
Re: How to import aiff Prpject files?
Create a new session and use the import audio feature.
Your problem might be that the aiff files can very well be 16bit which I think you need to convert to 24bit first, using itunes for example. Or create a 16bit session and try to import there.
Thanks |
Re: How to import Zoom MRS1266 files?
I tried to import as 16 Bit. No go.
I looked up Zoom MRS1266 Manual. From what I can find it might be SMF Files? Does that sound right? If so how do you suggest I import them? Thanks |
No.
SMFs are Standard MIDI Files, not audio.
Re: How to import aiff Project files?
It was recorded on a Zoom MRS1266. The project is dated 2001. I've looked thru the Online Manual but I'm not seeing what kind of Files? I read somebody's post somewhere they might be AIFF but 8 Bit?
I'm not seeing 8 Bit option in PT10? Maybe it's not do-able? Any ideas? Thanks |
Can you open/play the file in anything? Especially iTunes or QuickTime player?
What do they think the file format is? Or try doing a get info on the file from the finder if on a Mac. (I cannot recall what that actually tells you but I'll look when I am at my Mac). I am not sure bit depth in the file is an issue. The CODEC might be... AIFF is just a container format, it does not specify the CODEC, but I hope this is just plain old PCM audio. Still stuck share a file somewhere on a file sharing site and I can tell you exactly what the file format is and if it's corrupted etc. |
Thanks |
Desktop build: PT 2020.5 / Win 11 / i9-11900K @ 5.1GHz / 64GB / 4TB NVMe PCIe 4 / Gigabyte Z590 Vision D / PreSonus 2626 Laptop: PT 2020.5 / Win 11 / i5-12500H / 16GB / 1TB NVMe / Lenovo IdeaPad 5i Pro / U-PHORIA UMC1820 Ancient/Legacy (still works!): PT 5 & 6 / OS9 & OSX / Mac G4 / DIGI 001 Click for audio/video demo Click for resume |
Can't Import AIFF | Snowman999 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 07-08-2014 12:04 AM |
Can't import WAV, AIFF files | doughmiller | Digidesign Hardware & Software | 9 | 06-01-2006 08:43 PM |
Aiff import BUG? | OliJ | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 09-07-2004 10:37 PM |
AIFF import | ChrysalisEngineering | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 04-14-2004 07:28 AM |
Off Topic: Reason : How to import AIFF files of my own? | Mr T | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 11 | 09-19-2001 10:08 PM |
