Go Back   Avid Pro Audio Community > Legacy Products > Pro Tools 2020
Old 03-31-2020, 12:10 PM
SomeOtherGuy SomeOtherGuy is offline
Default MIDI edit issue in Main Edit Window
In the Main Edit Window (not MIDI editor), if you cut an area in the middle of a sustained MIDI note, nothing happens to the actual note, just the block gets cut.
In other software such as Logic Pro, an option window appears that says "Do you want to keep, shorten, or split the notes that cross the point where the region is being split."
Can we have this functionality in Pro Tools?
See this new Avid PT videos about 2020.3:
https://www.youtube.com/watch?v=CbL4...ature=youtu.be
If you make an edit across a sustained MIDI note it doesn't work.
Pro Tools Ultimate, Avid MTRX, MOM, MacBook Pro 16 (2023) 96 GB RAM, Mac OS Ventura, Samsung SSDs
Old 03-31-2020, 05:02 PM
Default Re: MIDI edit issue in Main Edit Window
See this thread:
http://duc.avid.com/showthread.php?t=382544
Old 04-01-2020, 07:09 AM
ZEUSS ZEUSS is offline
It’s time for a midi overhaul if you ask me. So many midi bugs like the disappearing note bug etc. They say it’s a standard in film yet you can barely compose with it. Poor VI performance, CPU spikes, sample rounding,etc. This one is a no brainer!
Mac OS 12.7.2 Monterey (19H15) Mac Pro 2013 (Trashcan) 6 Core 64 gigs Ram, Red Line 16, Native Thunderbolt, ProTools Ultimate 2024.3.1
Macbook Pro, 2019 (15,1) Mac OS 13.6.6 Ventura,32 Gigs Ram,2.3 GHz I9 8 Core ProTools Ultimate 2024.3.1, Apollo 8 Silver,TwinX.
Old 04-01-2020, 01:28 PM
foxes's Avatar
foxes foxes is offline
So on point! +100000000
iMac 27" Late 2013 3.5Ghz i7 32GB Ram 3TB HDD, 1TB SSD Samsung 850 Pro, Movaje 10.14.6, Pro tools 2021.7, 2021.3 & 2020.12 installed. UAD Apollo 8 Quad & Satellite Quad, Reason 10.4.1 & Reason Suite 11.3.9, Logic Pro X 10.5.1 (need to upgrade to Catalina for LPX10.6), plugins & VI's by practically everyone. G-Tech Mini 1TB HDD, 3 x 1TB Glyph GT050Q, Lacie Rugged 500GB & several assorted drives.....lots & lots of hardware synths & outboard
https://soundcloud.com/2b3productions
Old 04-02-2020, 12:03 AM
KimSira KimSira is offline
Yes, I'm very keen for this addition as well.
Split clip and notes at same time.
Midi Grid on Main Edit Screen? Sparky1 macOS 2 01-08-2019 01:56 PM
Edit Window graphics issue midnightrambler Pro Tools 12 9 11-19-2015 06:21 AM
Midi edit window stuck to edit window lvsranch Pro Tools 11 7 04-04-2015 12:42 PM
MIDI edit page.... Edit Window Scrolling ... Page Norm Mix MIDI 1 07-06-2009 07:31 PM
Edit window issue mmoorhead 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 03-18-2009 07:43 PM
