issue/bug with changing sample rates with RME card
Since around when PT10 was release, I've been having issues creating sessions at a higher sample rate than 44.1 Usually, if I try to create a session higher than 44.1 when I'm using my RME HDSPe AIO card. If I want to make a higher sample rate session I have to switch to the built-in audio card on my Mac and create the session, then switch back the the RME. I know this isn't a huge deal but it certainly would be nice if it worked like it used to when switching rates.
Usually the error I get is something like "could not complete the Open Session... command because Pro Tools could not set the sample rate to the specified value. This happens even when my converters/clock are set to the desired sample rate. I've tried restarting PT when this happens in a number of combinations, but the only thing that solves it is to create the session with the built-in Mac output and then revert to the RME, then it opens just fine. To me this sounds like more of an RME bug but RME pointed me to AVID (no surprise there)...since it seems very convoluted to reach AVID customer service I'm hoping somebody here might have a possible fix or soultion. thanks. |
Focusrite Saffire 56 Sample Rate Problems - Sample rates changing during start up | finalcut | Windows | 12 | 02-20-2012 04:00 AM |
Problem changing sample rates | BGee | Pro Tools TDM Systems (Mac) | 2 | 01-24-2007 12:18 PM |
Sample Rates... Changing Mid-project! | subsonicworld | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 1 | 02-14-2005 01:47 PM |
Changing Sample Rates | Jeffrey Talbot | Pro Tools TDM Systems (Mac) | 0 | 04-02-2003 01:43 PM |
Changing Sample Rates | lancegoiter | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 04-11-2002 03:48 PM |
