Pro Tools Hangs When Record Enabled
Lately I have been experiencing incredible lag (spinning beach ball in OSX) when tracks are record enabled within Pro Tools. It seems to have started a month back when I moved a session between an intel mac mini and my PPC G5 and it has gotten much worse. Im not sure what the problem is exactly, but the symptoms are as follows : When 1 or more tracks are record enabled, any sudden action such as stopping the transport abruptly after starting, can cause the session to hang for several minutes at a time. Ive tried trashing preferences as well as Disk Utility but neither have proven a solution. Ive moved sessions between my 2 external drives with identical results. If anyone has any suggestions, they would be much appreciated.
I am currently running Pro Tools 7.0 on OSX 10.4.3 Dual 1.8ghz G5/1.5 Gb Ram 160gb/300gb Maxtor firewire hard drives Thanks, - Mike |
Re: Pro Tools Hangs When Record Enabled
Currently Set at "Use All Available Space"
Would modifying this to a user defined allocation help? |
Yes, limit it to 10 minutes (or an appropriate value).
Rail
Thanks a lot to both of you for the assistance. I actually remember setting my allocation time to 10 minutes and disabling auto-save session backup when I first installed 7.0 but somehow both of these preference items had been reset. This seems to have alleviated my problem. This forum/user community really is great.
- Mike |
Pro tools 11 Record enabled problem | Jeffrey Kubiak | Pro Tools 11 | 11 | 11-19-2013 06:08 PM |
PT hangs with HEAT enabled. | Audioartist | Pro Tools 10 | 5 | 03-05-2013 12:44 PM |
Profire 2626 Recording into pro tools with no output on record enabled track | finkbmx | Pro Tools M-Powered (Mac) | 0 | 10-15-2009 09:02 PM |
Pro Tools Hangs when Record... | Grandox | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 3 | 08-24-2008 01:05 PM |
Pro Tools Hangs coming out of record | sevan | Pro Tools TDM Systems (Mac) | 3 | 07-18-2005 10:17 AM |
