#61
Re: Pro Tools Ultimate CPU Spikes.. come on!!!!
Double post
[B][SIZE="1"]System: PT 12.8.1 HD-Native PCIe, 48 I/O 16x16, 2012 Mac Pro 12 core 3.46Ghz 64gig RAM, UAD Quad FW, Apple 30” Cinema |
#62
Bump!! Avid!!!!!!!! Time for action!!!!
It's now been 9 months using 12.8.1 But I'm still paying every day for the support and upgrades and bug fixes! My last contact with Avid, remember I'm on all Avid hardware with a FULLY SUPPORTED and currently QUALIFIED Mac Pro: Entered on: 02.05.2018 10:38 Entered by: Maciej "Hello Andy, It's good that we found what is the issue. Unfortunately we have to wait until the upcoming release which should hopefully resolve it in some extend. For now the only workaround is to use the older OSX system with the older PT version which work much better on the older machines. Regards, Maciej Avid Customer Care | Audio Post & Pro" This was the eureka moment... and the bug found.... "Please try closing all the windows of ProTools and see if that get's the spikes out. (I have that issue here with other system and closing windows get's rid of the problem so if that's the cause I need to raise a critical bug) Regards, Maciej Avid Customer Care | Audio Post & Pro" Not being greedy, ..I'm a 20 year TDM user, and alway bought Digi/Avid hardware with a supported mac, to avoid such issues as I'm having now.. its truly embarrassing having to whinge! on this forum in order to get a stable version, that's not been tested correctly at Avid or it's Beta team in the first place. I've since ditched my HD native PCIe and bought HDX2 in hope this would remedy my situation, without luck.
#63
#64
Hi All!! I am running pretty much the exact same Mac Pro 5.1 as the OP, same amount of RAM and dual Hex core with a HD Native card. At the time of the error posting I was using El Crap. I updated to Sierra and my buffer errors were greatly reduced but did not disappear. I recently installed a SATA3 accelerator PCIe card and 2 SSD SATA3 HDs , one for OS and one for PT sessions and that certainly helped quite a bit. I can run larger sessions, of the medium variety, maybe 35+ tracks with just about as many plug ins @ 64 buffer with minimal issues. I STILL get an occasional buffer error but its rare. This is also a 24/48k session. Now I am also on PT2018.3 and I use no bluetooth and no wifi. I know, PITA.
This issue appears to me to be a HD NATIVE issues. Why? Because the same exact system ran 100% native has zero issues with buffer errors. Its the HD native card which I NEED because I NEED more than 32 i/o. AVID needs to fix this issue which is more than likely some kind of driver issue with the native card. A user by the name of s.d. finlay was also running into some spiking issues with a similar system to yours. He/she did report having some improvements after doing a complete reinstall of the system.[/QUOTE] |
#65
I'll post this agin here in case its relevant...maybe needs its own thread..
I've become convinced the poor low latency performance on PT NON-DSP is connected to how PT handles the graphics, rather than the audio. This is a quick demo video I made.. https://youtu.be/syhrOtDpaWg Its a typical rock/metal session i'm working on at the moment . 60 tracks of audio, 16 strereo auxes for bussing & FX, & bunch of plugins. Waves, Sonnox & AVID plugins used liberally throughout. I've armed a pair of tracks & am attempting to overdub with a 32sample buffer. With the Edit view running as normal in the background, we get the CPU spikes many of us have become familiar with. Switch off the Edit view (PT still recording in the background) & the CPU usage massively drops off. Switch Edit view back on & they return. Obviously working in the dark without the Edit view on is not very practical, but this does possibly point to where AVID could be making code optimisations .
A Rig: (Studio) I7-7700k Hackintosh - OSX 10.15.7, PT Ultimate2023.6 Native PCI-e Card, AVID I/O16 Analog i/o x2, 40 fader D-Command ES B Rig: (Home/Office). M1 Mac Studio - 64gb ram - OSX 12.7.1, PT Ultimate2023.6, HD Native Thunderbolt, Omni, Avid Artist Control http://www.lostboysstudio.com |
#66
hmmmm, that is a pretty interesting observation
Mac Pro '09 - 5,1 - Dual Hex Core X5680 3.33 ghz CPU - 48GB RAM 970EVO 500GB (10.13.6) - 1TB WD Black HDD (Samples) - 6TB Toshiba HDD (Backups) - 500GB Glyph GT050Q (Legacy sessions & backups) - 3TB Glyph Studio (Main audio/sessions) HD5770 GPU OSX 10.13.6 - Pro Tools 2018.12 - Presonus Studio 192 / Digi 003 Rack+ Focusrite Clarett OctoPre - AKG HPE6 - DBX160A - WA76 |
#67
Agree it is graphics related. Even making edit window smaller helps. I've tried this exact same test and get the same results.
#68
My findings: HD Native and HDX both share this issue, I'd only upgraded to HDX in the hope it was a native issue.. and it would go away, sadly not for me!
#69
Yes it's definitely graphics related. When I have a big mix and the cpu meter is bouncing around 70%. When I open Slate VMR or Fabfilter MB they usually cause playback to stop with an error. If I don't change anything on the screen the session plays back fine. It's the sudden change of graphics that seems to cause the problems.
Hackintosh 3.5 GHz Intel Core i7 - 10.12.6 -16 gigs Ram - Lynx Aurora 16 Thunderbolt - Protools 2018.3 HD Last edited by CHRIS AIKEN; 06-19-2018 at 02:34 PM. Reason: to show system info |
#70
Again here's the youTube I made for Avid 2 months ago, they asked me if closing (not minimising) edit and mix restored correct operation, having replicated my issue.
I think this is definitely the case, and I'm eagerly waiting on this critical bug fix, and maybe a 9 month refund on my support fee, as I had to spend two weeks uncovering this issue, that seemed to pass both Avid CS and Beta team, please check the you tube, and test your setup @ 96k 128 buffer, and let us know your findings. https://youtu.be/z82ZrOE0Dq4
Pro Tools Ultimate | YYR123 | General Discussion | 13 | 04-08-2018 10:24 PM |
CPU Spikes in Pro Tools 10, 11, and 12. | julia12345 | macOS | 9 | 11-25-2015 07:07 AM |
How to add Komplete 8 Ultimate into Pro Tools 10 LE | Ryan Tunis | Pro Tools 10 | 3 | 02-02-2012 02:13 PM |
Vista Ultimate 64 (the ultimate dissapointment) | Filmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 5 | 08-03-2009 04:44 AM |
