Old 09-15-2016, 01:08 AM
SD2 SD2 is offline
Default Video playback not playing right!
Hello,
I've read a lot about video engine problems but don't think I've read about this particular one.
I'm (sound) editing an animation movie.
Yesterday, everything was fine. Today, I've received a new version of the video with slight changes.
Going through the session to adjust editing to the new picture, I notice a scene were I'm not in sync. I stop and compare (frame by frame) the old picture with the new one and... no difference!
I replay the same part with the very same new video file and, this time, everything is just fine...
This has happened several times.
Not easy to work when you're not even sure that playback is correct!
My first guess is that it might be due to the fact that two video files are present in the session (exact same format though) but that has never been a problem in the past!
Am I the only one to experience this bug??
Thanks for any clue...
Pro Website
Administrator of Brotools, free online tutorials for the french Pro Tools user.
Old 09-15-2016, 06:29 AM
reichman's Avatar
reichman reichman is offline
Default Re: Video playback not playing right!
Make sure both videos are the same codec and frame rate. PT chokes sometimes if multiple videos in the edit window are too different from each other.
If you're still stuck, remove all video media from the session, close, re-open and then load only the new video and use Quicktime Pro in the background for your frame comparisons. Make sense?
Nathaniel Reichman
Supervising Producer – Re-recording Mixer
Dubway Studios
Old 09-15-2016, 08:04 AM
SD2 SD2 is offline
As said before, both videos are the same format. H264 seems to cause problem under PT12 (used to work fine under PT10).
I guess I'll convert to ProRes from now on.
Pro Website
Old 09-15-2016, 11:50 AM
MIKEROPHONICS's Avatar
MIKEROPHONICS MIKEROPHONICS is offline
H264 and your computer choking is your problem - as it often is in these posts.
H264 needs to calculate differences between key frames (real frames) to work out what to display on non key frames (this is how it keeps file size small) and why it is ****e for accurate playback. When your computer is busy, this performance drops off. Convert the videos to DNxHD36 and move on.
H264 is a codec for small file size and transfer only, not for playback.
cheers
Mike Aiton BSc (hons)
Dubbing Mixer/Sound Designer
BAFTA member
IPS member
former Post Production Expert at www.pro-tools-expert.com
www.mikerophonics.com
Old 09-15-2016, 11:58 AM
SD2 SD2 is offline
I know all of this, thank you.
But then, why does it work well under PT10?
Sorry for the post, this is going nowhere, forget it.
Pro Website
Old 09-15-2016, 12:00 PM
Because the AVE is not optimised to play h264. PT10 pretty much relied on QT engine and was god awful at sync unless you used a mojo and for rock solid awesome never drift sync, MXF media.
You are comparing apples to oranges with PT10 and PT12
cheers
BAFTA member
IPS member
Old 09-15-2016, 12:09 PM
SD2 SD2 is offline
OK, thanks.
Pro Website
Old 09-15-2016, 10:18 PM
Matt82au Matt82au is offline
i have had this issue with Pro Res. It isnt the fix. I literally find myself double checking 2 pips all the time in PT12!
Pro Res video running through AJA T Tap. Sometimes randomly so out of sync and then ok a few plays or restart later.
Has made me consider external video slaving for client attended sessions!
Matt Perrott
Sound Designer and Engineer
Sydney, Australia
Old 09-15-2016, 11:13 PM
SD2 SD2 is offline
Thanks, I feel less silly. ;-) :-(
Pro Website
Old 09-16-2016, 04:50 AM
Never seen that before. Don't often use P-Res
cheers
BAFTA member
IPS member
HTML code is On
Playing back a 3840x800 Video in Video Window Across Three Screens? dekstar253 Post - Surround - Video 1 10-29-2015 06:30 PM
.mov video not playing izzardisgod macOS 3 01-19-2013 02:28 PM
Video playing 4:3 instead of 16:9 darren wharton Windows 2 09-18-2011 11:42 AM
Lag when playing video in PT 8 girascopic Post - Surround - Video 3 08-28-2009 02:58 PM
playing video out of PT LE paul16 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 2 08-28-2006 03:56 AM
