Old 05-30-2014, 11:24 PM
thayne thayne is offline
Default HD/HDX Missing HD IO
I have the following:
Mac OS 10.8.5 12 Core 64GB Ram 10TB HD, Pro Tools 10.3.8 and 11, (2) Avid HDIOs, Pro Tools HDX, System 5 MC Pro
For some reason, not sure why, the second HD IO box is not registering with with Pro Tools. In the PT IO dialog box the Input and Output is assigned to the 2nd HD IO (B) but when looking at the Bus part of the dialog box it is showing that those channels are unavailable (N/A). All my Cue mixes are supposed to be running out the 2nd HD IO (B) box, therefore I have lost all my Cue mixes. I sure hope someone has some ideas here. I'm sure it is something simple but right now I cannot see the forest for the trees! I've attached pictures which may explain better. The files named "Old setup CTS" is from an old session that used to work. The file name with "vs" in it is the file showing the new set up on the left and the old set up on the right. Hope that explains the file naming.
Help would be very much appreciated!
Thank you,
Thayne
Old 05-31-2014, 02:25 AM
DetroitT's Avatar
DetroitT DetroitT is offline
Default Re: HD/HDX Missing HD IO
Hit Default in your I/O setup for each tab.
You may want to first select all and delete paths first.
Alternatively or for the future you can export/import your custom settings.
Deselect session overwrite.
If you still don't see all your I/O, check your hardware setup and or run the digitest to check firmware
(Help us Help You)<<<click here
Testing:All APFS 90% 10% Audio on HFS+(Testing 1.5 yr in)
Pro Tools U-2019.6 MacOS 10.14.6
Second boot-10.13.6 (Avid HDX-1 Omni)
(MP 5,1 / 64-Gb)
(Sapphire RX-580 MacVCEdition, 3-Displays)
MOTU FW-CoreAudio (for poly recording)
(SSL-HUI-MIDI over IP)
music-design-creation
Post Music-Sound mixing, Production-Enhancements.
Audio Tuning and System Services
Old 06-03-2014, 09:33 PM
Hi DetroitT,
I appreciate your help but after trying what you said and it still didn't work it got me to rethinking the whole situation.
I have 2 Avid HD IO boxes A and B. A is the only one that is linked via a patch bay for "manual" in and out connections. The B box is hardwired to the XMon box, my speakers (main, alternate, and surround sound) and my monitor system (control room and headphones (Cue mix)). Since I was not getting any sound from my headphones the light finally went on. The B box is also hardwired to the Ext portion of my PreSonus HP60 headphone amp. I must of had a brain freeze because I was trying to use the A & B sides of the PreSonus when I should have been using the Ext knob instead. Feeling rather like an idiot but at least it is fixed!!
Again, thank you for lending a hand it is very much appreciated!
Thayne
ProTools HD 10.3.6 - iZotope RX3 DlgDenoiser 'missing plugin' isn't missing paranerd Pro Tools HDX & HD Native Systems (Mac) 4 10-03-2013 07:39 AM
1 band EQ settings missing and Xpand missing? rockguitarist1255 Pro Tools 10 5 02-19-2012 04:33 PM
Missing fade files, missing audio in resaved sesssions drygruo 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 12-14-2010 04:56 PM
Missing Regions That Aren't Missing? stuseattle Pro Tools TDM Systems (Mac) 4 01-19-2009 01:56 PM
Pro tools says Files Missing but they're NOT missing.... nealobrien 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-13-2008 06:09 PM
