Old 08-26-2011, 02:37 AM
SmokinBaldMonkey SmokinBaldMonkey is offline
Default PTHD 9.0.5 Crashes on "Quit Pro Tools", Every Time.
No matter what I do, no matter what I try, PTHD9.0.3 began crashing on quit once I upgraded. Now I have PTHD9.0.5 which also crashes on quit every single time, without fail. I run 10.6.8 (PTHD905) and ran 10.6.7 for PTHD903, and earlier versions.
In session, out of session, when I try to exit pro tools, it CRASHES. If I try to launch it again without restarting my entire system, it will panic the system so hard I get screen freeze, and have to hard-shutdown my rig.
MAc Pro 2 x 3Ghz Quad Xeon
14 GB RAM
10.6.8
HD3/192/SYNC/C24
Veni, Vidi, Funki - I came, I saw, I laid the stank down
System 1: Retina MBP 512SSD/16RAM - Thunderbolt HDX1/HDIO
System 2: Mac Mini - 512SSD/8RAM - Thunderbolt HDX1/HDIO
OSX 10.8.5
Pro Tools 10 HD
Pro Tools 11 HD
SYNC HD
Old 08-26-2011, 03:15 AM
Hanswurstlsepp Hanswurstlsepp is offline
Default Re: PTHD 9.0.5 Crashes on "Quit Pro Tools", Every Time.
14 GB RAM
10.6.8
HD3/192/SYNC/C24
Did you trash prefs and repaired disc permissions and did the usual troubleshooting ?
PT9.0.5 works ok here - also the previous version.
No crash on quit - no problems with elastic audio and/or importing files from workspace here.
http://duc.avid.com/showthread.php?t=240754
Cheers, STeff
MacPro5,1 , 32 Gig Ram, 2xATI Radeon HD 5770, OSX10.13.2  Pro Tools|HDX Ultimate 2018.4.0  HD I/O&192Digital&96&96i I/Os  D-Command ES  4xUnitor8 & 2xAMT8
Old 08-26-2011, 04:40 AM
crizdee's Avatar
crizdee crizdee is offline
14 GB RAM
10.6.8
HD3/192/SYNC/C24
I would also check all your plugins are up to date! I've seen this cause crashes when closing!
Chris
Producer, Engineer,
Slow Readers Club_Build A Tower top 20 UK album charts
www.ukmastering.com
PT10.3.10 Mountain Lion HD6 accel Magma PE6R4 Control 24 MacPro 12 Core 3.46ghz UAD-2 Octo x2. Manley Vari-Mu, Manley Massive Passive, SSL VHD, ADL600, Grove Tubes ViPre, Tube-Tech CL-1B. Hafler TRM active monitoring.
Old 05-19-2012, 01:53 PM
Paul Dews Paul Dews is offline
Im having a similar problem with Protools LE8. Everything runs fine but when I try to exit a session in the file menu my computer crashes(Protools not responding) and I have to pull the computers plug out of the mains in order to be able to start up again.
Any advice anyone? Cheers.
Old 06-04-2012, 04:34 PM
bonfi64 bonfi64 is offline
reinstall version 8.1.1 and you'l be fine
Strange "Assertion" error causing Pro Tools to quit unexpectedly...???? nickbradbury macOS 13 09-10-2014 03:50 AM
Pro Tools 11 quit/crash when typing "Shift" Fir3bird Pro Tools 11 24 07-07-2013 07:48 PM
Pro Tools 10 "quit unexpectedly" constantly after install! mr punch macOS 13 01-23-2012 10:46 AM
Pro tools 9 crashes at startup "Bus error" in thread "MainThread", at address 0x0 danball macOS 2 09-26-2011 04:49 PM
"Pro Tools LE quit unexpectedly" tried every solution I can find.... HorizonsDOUG 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 09-08-2011 11:06 AM
