Old 07-19-2018, 03:36 PM
Goombot Goombot is offline
Default Track Preset issues
I'm having issues with Track Presets in ProTools Ultimate. First issue is that nothing is saving when I select the "clips in Edit Selection Only". Every time I select that I get the error "Could not save because out of range..." I can save if I leave that unchecked. I go to my Track Presets folder and see a .ptxp file with, for example, a 400mg size. When I go to Recall Presets I can see it (when I right click), I select it and nothing happens. When I go to the Workspace browser to see if it's there it is missing. So it's not working as it should.
Old 07-21-2018, 05:14 PM
Default Re: Track Preset issues
So has anyone had this issue? Can Avid check in about this? I've tried on two separate machines, two different sessions and still getting the same error. It works fine if you don't check the "clips in Edit selection only" but otherwise it never works.
Old 07-22-2018, 12:31 PM
Update. So the track presets with media do work for me in a small two track session so there is something about the bigger sessions that seem to make it not work. Also, when I recalled the track preset in the smaller session it did not spot or follow the timeline selection. It didn't even place the clips at the top of the session. It seems totally random.
Old 07-26-2018, 06:10 AM
Speedsound Speedsound is offline
You're not alone...
I have exactly the same problem with long session....(i work in post)
Ptools Hd 18.4 on Sierra
Old 07-26-2018, 01:06 PM
I spoke with Avid yesterday at length and did a screen share. It seems that this doesn't work with any audio imported from an AAF which is completely ridiculous since it seems primarily created for people in post. I had a session where most of the clips were brought in from an AAF directly from Media Composer version 8.6.5 and none of those clips could be saved as a track preset. I did have files that I directly created in the PT session after the import and those were able to be saved. We also did a Save Copy as and none of that worked either which was very strange so there is either some issue with metadata or unique ID or something further bedded into the audio. Either way it doesn't work yet. They told me that I was the first person to contact them with this issue which I find pretty hard to believe.
Old 07-27-2018, 06:03 AM
I It seems that this doesn't work with any audio imported from an AAF .
Thank for sharing info
But,i don't think so....
No AAF and no OMF import in my 5.1 edit session...
If i try to do a track preset with one of my stems with all audio clips (90mn session)
It work
If i try to do a track preset with one of my stems with only 2mn of audio clips(90mn session)
(clips in Edit Selection Only"
It crash ("Could not save because out of range.)
If i move 2mn of audio clips on an empty stem(without audio clip before and after my selection),and do a track preset (90mn session)
(clips in Edit Selection Only")
It work
anyone had this issue ?
Old 08-01-2018, 02:50 PM
philip_purcell philip_purcell is offline
I’m getting this as well (the “out of range” error). Also sometimes track presets that saved ok have missing media when re-imported - some empty clips, although some clips are ok. My sessions are always from AAFs although it doesn’t make any difference whether media is MXF or WAV. This would be a great feature for post if it worked properly.
Old 08-01-2018, 10:11 PM
OK, so on further investigation, it's not actually clips from AAFs - just clips from field recorders. When I de-selected my location tracks, it worked, even though there was a music track that came in via AAF.
Old 08-22-2019, 01:59 AM
nicolasvr nicolasvr is offline
Hi guys
On ProTools Ultimate 2018.10.0 on a MacOS High Sierra 10.13.6 at work.
Having the same issue with this 'out of range-poly alt' error-message when trying to save a Track Preset for multiple tracks with clips selected over a region.
And in the sessions I work on there are no AAF/OMF imported tracks or Field Recorder Guide Track linked-tracks. Only sounds from libraries.
Anybody got to find a solution for it? I already trashed the preferences but it didn't help..
greets
Dell Inspiron 17-7778 laptop
2.6 GHz Intel Core i7-6500U
16GB RAM - Win 10 Pro
Pro Tools 11
Old 08-22-2019, 04:44 AM
musicman691 musicman691 is online now
Originally Posted by nicolasvr View Post
Hi guys
greets
According to the compatibility chart PT 2018.10 is not compatible with OSX 10.13.6; it's only good up to OSX 10.13.3 so that may be the problem.
Recall track preset colliderman Pro Tools 2018 0 03-17-2018 06:20 AM
Track Preset hack JeffFormosa Pro Tools 12 3 06-29-2016 05:03 PM
Track preset Hack questions Suke Tips & Tricks 2 01-12-2016 04:26 PM
Patch preset loading issues and CPU Overload notedmusic Pro Tools 11 2 02-04-2014 04:31 PM
PT10 Track Preset mehrdadp Eleven Rack 1 12-16-2011 01:21 AM
