How to Join & Post  ē  Community Terms of Use  ē  Help Us Help You
Knowledge Base Search  ē  Community Search  ē  Learn & Support
Old 06-11-2019, 02:55 AM
JFreak JFreak is online now
Default Re: 6-core vs. 12-core MacPro w/ ProTools
Originally Posted by Marsdy View Post
Iíve only just moved to 2019.5 and Mojave so Iíve yet to test if there has been any improvements in CPU usage with VIs
You might be surprised how good it is
Old 06-11-2019, 04:17 AM
Cheesehead Cheesehead is offline
I agree, there's a really noticeable improvement in multi core cpu handling in 2019.5. The extra voices are great too and seem to take the load off, at least in my workflow.
Mac Pro 6,1 12 core, OSX 10.14.6, HD-Native TB, Trinnov MC, 888 IO, 192 IO, Sync HD, AJA IO XT, MC Mix, PT Control, Eucon 19.9, PT 2019.6
Old 06-11-2019, 06:34 AM
off the wall's Avatar
Originally Posted by Oliver M View Post
Stick to the 6-core, the 12-core will not improve performance with PT. The RAM will make the difference though.
I think that is really dependent on the plug-ins you are running in a given session. Pro Tools itself uses all the cores. With the combination of mix plug-ins I typically use, I noticed a huge improvement going from 8 to 12 cores on my 5,1 Cheesegrater.
offthewallproductions
Mac Pro 5,1 3.46 Ghz 12 core, AMD 7970 GPU, SSD boot drive on 6Gb/sec PCIe card, 36GB RAM, MacOS 10.14.6.
Pro Tools Ultimate 2019.6. HDX, UA Octo PCIe cards, HD I/O, C|24 control surface.
Mostly Avid, Waves, Sonnex and UAD Plug-ins
Old 06-11-2019, 09:30 AM
Eric Lambert's Avatar
I'll be using 2019.5, so core distribution is much improved over previous versions. I do know that single-core operations will be slower on the 12-core due to its clock speed, but most of the apps I use employ all cores.
I do use Vienna but it's never pressed my CPU too hard, and I'm 99% certain that it uses all cores (there are preference settings related to this). Plugins that do eat CPU are u-He products, Output's Arcade (terribly buggy, especially when taxing the CPU), and of course some of the modern reverbs.
Old 06-11-2019, 09:49 AM
Marsdy Marsdy is offline
The VE Pro app itself uses multiple cores but does the VE Pro plug-in in PT do so too, or for that matter any other single plug-in instance? My point is I do get VE Pro CPU spikes on my trashcan 12 core when an instrument track is record armed and the PT dual buffer thing comes into play. This is on demanding Kontakt instruments though.
Just out of interest Iíve run my Kontakt stress test session in 2019.5/Mojave. It wonít play back and just locks PT up. It DID play fine in 12.6.1 (PTs best ever version for me.)
That said the BIG variable is I was using Kontakt 5 in 12.6.1 and Iím now running K6. Disappointing though. Iíll try Kontakt 5 later if I get time.
Dave Marsden
UK
Avid HDX1, PT12 HD, HD I/O 16x16, Avid S6 M10 24-5, 2013 12 Core Mac Pro. Robby The Robot meter bridge ornament.
Old 06-11-2019, 10:19 AM
TThat said the BIG variable is I was using Kontakt 5 in 12.6.1 and Iím now running K6. Disappointing though. Iíll try Kontakt 5 later if I get time.
Earlier K5 were much better than the later ones, K6 is a hog
Old 06-11-2019, 10:29 AM
Agreed, and I'm not upgrading to K6.
Old 06-12-2019, 08:41 PM
685 685 is offline
The 6core Macmini looks cool so I would guess that the 8core iMac would do more.
http://www.pro-tools-expert.com/prod...or-your-studio
Old 06-12-2019, 09:36 PM
I installed the 12-core CPU tonight and the increase in processing power is not subtle. Technically, my previous 6-core Geekbenched at 20,712 and with the 12-core it's now 32,011. That's a significant increase, and I can feel it in ProTools and everywhere else. And it was only $500 all-in. Far better than buying an entirely new refurb for $3k.
Old 06-12-2019, 10:41 PM
Good to hear
Upgrade my 6 core 2013 MacPro to a 12 core, or get a new 6 core when released? jaminjamesp macOS 2 03-15-2019 03:26 PM
Macbook Air 2014 (1.4ghz Dual-core Intel core i5 Vs. Mid 2010 MBP i7 Quad-Core and PT TheGoodhusbands Virtual Instruments 2 09-11-2015 10:49 AM
Protools HD 9 / MacPro Dual 6 Core roberts Pro Tools 9 0 11-12-2010 10:15 PM
help with the new macpro 8 core running protools LE frostyeve 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 10-30-2010 09:06 PM
MacPro 8 core runs Mpowered better on only 1 core??? textiles Pro Tools M-Powered (Mac) 5 08-25-2009 01:13 PM
