Which New iMac?
Hello friends,
I'm days if not hours away from pulling the trigger on a new 27" iMac with an i7 and 512g flash drive (I'm getting minimum 8g memory and beefing it up to 24g with Crucial). But my question to you is: what is the difference between the two upper end iMacs? One has a slightly faster processor but is it worth the extra $300? Would I feel a significant difference? I'm doing Pro Tools on this machine and not gaming. Your thoughts?
Brian See profile page for system details |
Re: Which New iMac?
And because itīs 64bit Pro Tools 12 you want to run on this iMac and you want it to work flawlessly as for the computer you definitely want the +$300.- i7 Quad Core processor! You know, some people use PT12 with i5 processors successfully as well but from my own personal experience (I have used PT12 on i5 and i7 Quad machines) you really should go for an i7 Quad Core processor on buying a new Pro Tools 12 computer. It simply does work better and more reliably at the end of the day. If buying such a high end iMac you better not save at the processor. What you could do to save another $150.- would be to go for the 3.2GHz Processor model (not the 3.3GHz model) which starts at $1999.- instead of $2299.- for the 3.3GHz model, then add the 4.0GHz quad-core Intel Core i7, Turbo Boost up to 4.2GHz processor (which you will have to do in either case), go for 8GB Ram only and the 512GB Flash drive. Both models are almost identical in this configuration except the graphic engine. The 3.3GHz model does come with an even more powerful graphic engine than the 3.2GHz model which will add those $150.- finally. And thatīs where you could save a few bucks without affecting the performance of Pro Tools 12. The graphic engine of the 3.2GHz model will be powerful enough to run Pro Tools as it is supposed to. http://www.apple.com/shop/buy-mac/imac So my suggestion would be to go there and scroll down where it reads -3.2GHz Processor 1TB Storage- for $1999.- instead of where it reads -3.3GHz Processor 2TB Storage- for $2299.-. Then add the 4.0GHz i7 Quad Core processor, leave it at 8GB Ram and go for the 512GB Flash drive. You will end up with $2,599.00 instead of $2,749.00 finally. Not that much but $150.- difference at least. If you are on a seriously tight budget you even might go for the 256GB Flash drive only and use an external USB 3 7200rpm HDD for your Pro Tools sessions/audio files which you can replace (when there will be more money available for it) with an SSD using the same external USB 3 enclosure later. You could start out with such a one https://eshop.macsales.com/item/West...al/WD5000LPLX/ in such an external USB 3 enclosure https://eshop.macsales.com/item/Othe...ting/MOTGS3U3/ and put such a SSD into the same enclosure later for example https://eshop.macsales.com/item/OWC/SSD7P6G480/ https://eshop.macsales.com/item/OWC/SSD7P6G960/ The start configuration with the 500GB 7200rpm HDD and the external USB 3 enclosure will be $93,74 all together instead of +$200.- for the 512GB Flash drive. Another $100.- saving. Just as an idea if your budget is that tight. Just donīt save at the processor with such an high end iMac particularly if you want a current, well working Pro Tools 12 recording/mixing system for the next few years. Anyway itīs up to you of course finally. Wishing you the very best of success. Cheers. |
Re: Which New iMac?
"What you could do to save another $150.- would be to go for the 3.2GHz Processor model (not the 3.3GHz model) which starts at $1999.- instead of $2299.- for the 3.3GHz model, then add the 4.0GHz quad-core Intel Core i7, Turbo Boost up to 4.2GHz processor"
Yes, VRW, this was my intention all along. I will buy the next-to-coolest iMac and beef it up to an i7 and a 512 flash drive. Your answer confirms my thought that the next highest Ghz rate is probably only useful for video and gaming -- neither of which I will be doing much on this iMac. Thanks again, as always!
Re: Which New iMac?
There is no difference in the GHz rate with the i7 Quad option for both of them. They only differ in GHz rate with their basic i5 processors. The i7 will be exactly the same for both finally. Means by choosing the i7 Quad option for your iMac (no matter which basic model) you get the most powerful processor for an iMac available at the moment. There ainīt another more powerful processor for an iMac available at the moment than this 4.0GHz quad-core Intel Core i7. Cool indeed. And very useful for the use with Pro Tools nowadays. I guess you eventually will have lots of fun with this machine. Cheers. |
Re: Which New iMac?
Re: Which New iMac?
Thanks Jack,
Yeah I thought I'd see how well it does with 24g of memory. The iMac ships with two 4g chips. I'll add two 8g chips from Crucial and see how it does. It would be easy enough to get two more 8g chips to make it 32g of memory. The i7 is a must. And I'm getting the 512 of flash storage. No Fusion confusion here! Oh, and VRW...I picked up my new Focusrite Clarret 2Pre and my new Neumann TML-102 yesterday. Can't wait for the new 'pooter so I can set them all up!
Re: Which New iMac?
One thing I would do is to try out the machine in stock form when you get it to make sure everything works. |
Re: Which New iMac?
And that's a good idea to fire up the new iMac with the stock 8g of memory. Should I put it through small PT session too? How much of a test should I give it before I add the new memory?
Re: Which New iMac?
Doing a small PT session won't hurt in your initial checkout. The reason I mentioned about doing a checkout with the machine as you get it that while it passed final QC at the factory you never know what can happen in shipping where something can work loose or worse. Just be sure to save all the packing material. I purchased a PolyEvolver rack mount synth module some years back and it was dead on startup at my place. It's called infant mortality and can happen to even the best companies. |
Re: Which New iMac?
All great advice, Jack. Will do...and thanks!
Tranferring Protools 10 from old iMac to new IMac | JuergenTilak | Pro Tools 10 | 3 | 07-31-2012 08:48 AM |
24in iMac or 21.5 iMac??? Help | the blast | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 09-30-2010 05:19 PM |
M Box 2 and new iMac | lugg0 | Pro Tools M-Powered (Mac) | 1 | 06-17-2010 02:24 AM |
sync iMac with 003 and iMac with Mbox2? | Jussi | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 4 | 03-09-2009 03:24 PM |
Mac Pro or iMac for PT LE? | hoke | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 10-28-2007 09:04 PM |
