AAE error 2 was encountered. HELP!
Good afternoon, all.
After the 11.2.2 install I started seeing the AAE error 2 was encountered message when opening existing sessions. Creating new sessions seems to work fine. I checked the knowledge base couldn't find the meaning of this error. Anyone? Regards, Francisco Pro Tools 11.2.2 Mac Pro Late 2013 Yosemite 10.10.1 UA Apollo |
Could this be a Yosemite situation ?
Have you tried making a new session then importing session data from the old session ?
~ 2019 Rack Mac Pro 3.2 GHz 16 core 384 GB RAM Catalina 10.15.7 / Pro Tools Ultimate 2022.12.0 / HDX 2 + UAD2 PCIe OCTO+QUAD / HD I/O's x 4 + 1 x 96io / Digidesign Pre's x 3 / Avid S6 M10-24 -V22.12.1.34 ~ ~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / Magma PE6R4 ~ ARCHIVE RIG ~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~ |
Re: AAE error 2 was encountered. HELP!
Thanks for the response.
I was able to import the problem session data into a clean session. No AAE error appears. Regards, Francisco |
Restarted the computer. It appears that my sessions is fine.
Rebooting ever fails! :) I am still curious as to what the root/cause of that issue is. |
Hhmm. Well … there do seem to be a lot of "don't upgrade to Yosemite" notes / warnings around.
Not sure if this is a Yosemite specific issue. I'm getting constant AAE error 2's under 11.2.2 on Windows, something I didn't see with previous versions.
I get these errors occasionally after importing session data, then recalculating waveforms (as the waveforms often don't show up on the imported tracks... another bug). Closing and re-opening the session clears it up quickly, though.
ProTools HDX 11.2.1 on Mac OS 10.9.4. MacPro 6,1, 6-core, 32 GB RAM |
I have this same issue but I have it on a windows computer. Every time i try to do a play back or if i record something and play it back this error comes up.
ProTools HDX 11.2.1 on Windows 7 Lenovo 64 Bit - i5-4300m cpu 1TB |
tallson, did you ever resolve this error? I am in the same boat.
, Zuma M-box II Pro Windows 7 |
Make sure no identically named disks are mounted, quit ProTools and relaunch it.
Help! I get the error 'pro tools has encountered an unrecognized component' error | gsmith135 | Windows | 10 | 12-17-2014 01:08 PM |
error 706 was encountered | Russkull | Pro Tools TDM Systems (Mac) | 2 | 08-25-2008 09:23 AM |
DAE error 7 encountered. | Smoovie | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 2 | 01-22-2004 07:55 AM |
DAE error was encountered while trying to connect (error #-7101 | Enis Presheva Jr. | Pro Tools TDM Systems (Mac) | 1 | 06-07-2001 12:45 AM |
DAE Error -50 was encountered HELP! | MacDigidesign | Digidesign Hardware & Software | 4 | 10-26-2000 06:39 PM |
