Old 11-21-2019, 07:27 PM
tangoportland tangoportland is offline
Default MY Templates Not Showing after folder moved
Hello Community, I have a bunch of templates saved that are in a folder called MY Templates, I moved the folder because it was in the C drive in the desktop folder with a bunch of Drum samples.
Then I moved it to User>My Documents>Pro Tools > Session Templates
But, now when I try and create a new session from a template the Folder does not show up in the drop down choices and it has added a bunch of new (stock templates ) that I never have or will use.
How can I get my old Folder "MY Templates" to be visible again for a template choice in the drop down menu?
Do I have to reset something ?
I should have just left it alone !!!
Thanks
Old 11-22-2019, 03:25 PM
Default Re: MY Templates Not Showing after folder moved
SOLVED
Navigate to the Setups menu within Pro Tools
Open the Preferences and click on the Operations tab
Click on the "Change" button located at the bottom left of the operations window under User Library > Root: Change
Set that to the Hard Drive > Users folder > your current user > Documents folder > Pro Tools folder
Note: within the Pro Tools folder will be a Session Templates folder with templates.
Don't set to Session Templates. Simply set to the Pro Tools folder
iLok issues - plugins being moved, not showing booter Licensing & Accounts 3 09-10-2018 05:04 PM
Plug-in folder moved colourednoise Windows 4 04-01-2013 05:47 PM
groove templates folder..????? dan05 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 03-26-2009 09:05 AM
Moved sessions to a folder, files can't be found BRAVO-STUDIO 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 12-01-2004 12:09 PM
Error Playing a Session Folder That Has Been Moved Matt_G Pro Tools TDM Systems (Mac) 5 06-14-2004 11:14 PM
