Old 05-23-2020, 04:42 PM
swethington swethington is offline
Default s1 not cycling through automation modes to 'read'
I recently updated EuCon, Pro Tools and my s1 firmware to the latest versions and I'm having an issue where using the s1 to cycle through automation modes isn't working quite the same as it did. I'm only able to select touch or latch modes, any additional selections of the automation button for that track don't cause it to cycle back to read. I'm very new to the s1 (just started using it a few days before this newest update) so it's very possible this is user error and if so I'm hoping someone can point me in the right direction. I see in the newest 'using EuControl surfaces PDF' it mentions that write and trim modes aren't available through cycling but it doesn't mention read.
I can select read mode from Pro Tools or from the channel page of the Control app, it's just the s1 that isn't cycling back to that option. Any ideas?
thanks!
Mac mini M1, 16 GB RAM, Ventura 13.3.1, Pro Tools 2023.3, Avid S1, UA Apollo Twin UAD-2 Satellite
Old 05-24-2020, 09:26 AM
EddieJones's Avatar
Default Re: s1 not cycling through automation modes to 'read'
I just tied this and its working OK for me. Do you still have the issue ?
Old 05-24-2020, 10:59 AM
Yeah, still seeing the same issue. Thanks for checking on your end though, makes me think there's something specific to my setup/installation that is problematic.
Old 06-02-2020, 09:03 AM
pherzfeld pherzfeld is offline
I am having the same issue with my 2 Artist mix setup. The Artist Mix cycles from read (its default state) to touch, to latch - then stops and wont do anything else. Pro Tools 2020.5.0 Eucon 20.5.0149
Old 06-02-2020, 09:35 AM
Yeah I'm still having the same issue here too. I did a clean re-install of my OS, apps, etc (not for this reason, was having some other issues) and no change. Anyone else having this issue?
Old 06-02-2020, 05:30 PM
JingleDjango JingleDjango is offline
Me too. The latest Eucon/Avid Control update broke a lot of functionality for me. Really crippling my workflow.
Old 06-03-2020, 09:11 AM
EddieJones's Avatar
Can someone post a video of this happening as no one here can reproduce this so there must be something we are missing. In the video please show the EuControl settings and the automation window in PT
Old 06-03-2020, 09:48 AM
Here you go, Eddie. Hope this is helpful.
https://youtu.be/OExS1IllUqs
Old 06-03-2020, 10:02 AM
EddieJones's Avatar
Thanks for that. Could you try setting the option in EuControl so you dont need the shift and see if its the same ?
Old 06-03-2020, 10:08 AM
Would that be 'Latching Shift'? The latching function works generally but automation mode still will not cycle patch 'touch'
Global Automation Modes (and more...) PatrickCusack Avid S4/S6 1 04-10-2018 09:36 PM
System 5 MC Automation Modes Mike Hybrid System 5 6 07-10-2014 02:14 PM
Shortcut for cycling automation SZE Post - Surround - Video 3 09-24-2009 09:47 AM
change automation modes? Richard Fairbanks ProControl, Control|24, Command|8 2 07-11-2007 04:02 AM
bcf2000 & automation modes?HOW? maltezze 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-29-2006 06:59 PM
