Go Back   Avid Pro Audio Community > Pro Tools Software > Pro Tools 2020
Old 04-16-2020, 06:07 AM
doylemusic doylemusic is offline
Default Digital Noise on BTD and Recording
Hello All
Having some really weird issues and looking for some thoughts/help. I'll try to describe the issue and provide info.
Essential issue is any bounce to disk or recording of audio results in some weird digital noise along with the audio, making it un-useable.
Example:
http://visitor.doylemusic.com/PT_audio_issue.wav
I'm running PT 2020.3 on Win 10 Pro 1909, so I think I'm compatible. I use two Lynx Aurora 16's with one HDX card. I've double checked my graphics card and drivers.
When I run a digitest with both or one of the Lynx connected and on, I get PIO and TDM PIO errors. When I run the test without the devices powered on, it passes. The firmware on the units is up to date. I've worked with Lynx support and they dont think the converters are a problem after running through multiple tests. Especially since converters are not part of the "bounce-to-disk" process.
When I set my playback engine to Windows Audio Device, the audio is fine.
Any thoughts?
PT Ultimate 2020.3.0
1 HDX Card
Lynx Aurora 16 (2)
Windows 10 Pro 1909
ASUS X-99 II
Intel i7
32GB RAM
Gigabyte GeForce GTX 1050 Ti 4GB
www.doylemusic.com
Old 04-16-2020, 07:11 AM
Default Re: Digital Noise on BTD and Recording
One additional note, my preferred setup is to clock both Aurora externally to an Antelope Audio Pure 2. I have tested clocked internally as well. But honestly not thinking this is a converter issue, seems something more PT related.
Just trying to give as much helpful info as I can :)
1 HDX Card
Lynx Aurora 16 (2)
Windows 10 Pro 1909
ASUS X-99 II
Intel i7
32GB RAM
www.doylemusic.com
Old 04-16-2020, 11:55 AM
The Weed's Avatar
The Weed The Weed is online now
Run LatencyMon and see if there is something causing your issue.
non-union national read at a reasonable rate
Demos: brucehayward dot com
Source-Connect: brucehayward
Old 04-16-2020, 12:47 PM
Are you using any hardware inserts in the session? Does it happen with all sessions or just this one?
Old 04-16-2020, 12:48 PM
I'll check. Ran it and it says everything is good. I dont see any issues, unless I'm missing something. Never ran the tool before, so....
1 HDX Card
Lynx Aurora 16 (2)
Windows 10 Pro 1909
ASUS X-99 II
Intel i7
32GB RAM
www.doylemusic.com
Old 04-16-2020, 12:49 PM
Happens with all session. My current test session is literally one imported stereo file. No inserts, plugins, etc.
1 HDX Card
Lynx Aurora 16 (2)
Windows 10 Pro 1909
ASUS X-99 II
Intel i7
32GB RAM
www.doylemusic.com
Old 04-16-2020, 04:14 PM
The Weed's Avatar
You need to run it for a bit, like 5 minutes or so. It sometimes takes a while for issues to show up.
Also, have a look at this Thread.
Old 04-16-2020, 08:15 PM
Ok, ran it again and got this:
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One or more DPC routines that belong to a driver running in your system appear to be executing for too long. At least one detected problem appears to be network related. In case you are using a WLAN adapter, try disabling it to get better results. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:01:21 (h:mm:ss) on all processors.
Went through your post and re-checked Optimization for Win 10. Thought I had disabled hyperthreading before but somehow it was enabled. I dis-abled that, turned off Turbo and c-State. Also tried updating Network driver.
Ran CCleaner to clean registry.
Re-tested and got the same error in Pro Tools and same errors in LatencyMon.
Rebooted and re-ran Latency mon again and got slightly different error:
Your system appears to be having trouble handling real-time audio and other tasks. You are likely to experience buffer underruns appearing as drop outs, clicks or pops. One problem may be related to power management, disable CPU throttling settings in Control Panel and BIOS setup. Check for BIOS updates.
LatencyMon has been analyzing your system for 0:07:47 (h:mm:ss) on all processors.
Thoughts?
1 HDX Card
Lynx Aurora 16 (2)
Windows 10 Pro 1909
ASUS X-99 II
Intel i7
32GB RAM
www.doylemusic.com
Old 04-16-2020, 08:16 PM
I dont see anywhere to disable throttling in control panel or bios (uefi).
1 HDX Card
Lynx Aurora 16 (2)
Windows 10 Pro 1909
ASUS X-99 II
Intel i7
32GB RAM
www.doylemusic.com
Old 04-16-2020, 08:41 PM
sw rec sw rec is offline
Running a secondary hard drive, or recording to the system drive?
Audio Recording Noise Test on a new laptop.How do I reduce fan/system noise? PeterGreen Pro Tools 10 24 01-23-2013 06:38 AM
Digital noise and glitches when recording to gdrive antward Pro Tools M-Powered (Mac) 2 05-13-2011 07:43 AM
Digital noise on my digi002 when recording Matmorfus 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-06-2006 02:43 AM
Digital noise from PT Voxer 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-19-2005 01:33 PM
Recording 16bit digital to 24bit digital Tips & Tricks 2 03-13-2000 11:37 PM
