Go Back   Avid Pro Audio Community > Pro Mixing > Avid S6
Old 02-26-2018, 04:45 PM
karegranat karegranat is offline
Default Layouts not stored within session
Hi, guys!
The post topic says it all. Everything else seems to be saved and recalled correctly, but I always have to load my layouts from the S6 system itself. Shouldn’t layouts used within a pro tools session also be stored/recalled within the session and not rely on external storage?
Best, Javed.
PT 2018.1 HD
S6 M10 3.7.0
Old 02-26-2018, 10:29 PM
priorytools priorytools is offline
Default Re: Layouts not stored within session
Jav’… have you double checked in your S6 settings. I can’t remember if it’s in “user” or “system”, but in there somewhere is a table of elements you wish to save with sessions.
~ Trashcan Mac Pro late 2013 - 64 GB RAM - 10.12.6 / Pro Tools Ultimate 2019.6 / HDX 2 + UAD2 PCIe OCTO in Magma Expressbox 3T / HD I/O's x 4 + 1 x 96io / Avid S6 M10-24-5 V19.12 ~
~ MBP 15" 2.8 Intel Core i7 -10.12.6 /Apollo 16 / Steinberg U22 / Artist MIx / Pro Tools HD 12.8.3 - UAD2 V8 / UAD2 Satellite DUO ~
~ Mac Pro 8 core - clover - 13 GB ram - 10.6.8 / HD5 / Pro Tools 9.0.6 / HEAT / Magma PE6R4 / ProControl 24 faders / UAD2 QUAD PCIe ~ ARCHIVE RIG
~ Mac Pro (Early 2009) - 2 x 2.26 GHz Quad-Core-32 GB RAM-10.13.6 / Pro Tools Ultimate 2019.10 / Apollo 16 / Avid S3 ~
Old 02-27-2018, 01:26 AM
Hi, priorytools!
Yes. If you are referring to "System/General/Preferences/Auto-Load From Titles And Sessions", I have everything ticked except from "User Preferences". So "Layouts And Meters", which seems to be the relevant option, is also ticked.
Anything else I should check?
Best, Javed Kurd.
Old 02-27-2018, 05:49 AM
Originally Posted by karegranat View Post
Hi, priorytools!
Best, Javed Kurd.
Pres the WS button & in the master module soft keys display, make sure Pro Tools has the blue star next to it, if it doesn't press the soft key next to Po tools to assign it.
Old 02-27-2018, 07:59 AM
That did the trick! Thanks alot!:)
Old 02-27-2018, 09:18 AM
recall layouts on session opening kkfaudio Artist Series 0 10-12-2016 07:39 AM
Import Session Data & Layouts priorytools Avid S6 3 03-17-2016 11:50 AM
Does delay compensation settings get stored with a session? johnnyv Pro Tools TDM Systems (Mac) 1 07-10-2010 08:03 PM
Bringing stored session back from CD... Roy Howell 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 13 02-16-2002 01:32 AM
External HD, What get's stored on it? MX795 General Discussion 3 12-21-2001 09:28 AM
