Old 02-19-2011, 04:25 PM
oulablank oulablank is offline
Default Fade Bug . Has This been covered ?
I did some searching but couldn't find anything on this . Wondering if it has been a topic already b/c I've been away for a month.
Put a fade on a region . Drag it all the way to the beginning of the region . Now zoom in as far as you can and you'll see that the fade won't go all the way to the beginning of the region . So if you went to consolidate this region and didn't know this , it would create two regions . I found this out b/c I like to create my own printed click track using a sample as opposed to using a click plug . I picked my sample , trimmed , fade and consolidate so it would rename my region and then paste / repeat to end of song . Obviously everything got screwy from there . My workaround is the as simple as selecting that little sliver before consolidation but it's still annoying.
Oh 1 more thing since this is on topic on bugs / making a click track from sample.....If you want make a click track like I do ( and have it adjust to your tempo after the fact ) you need to set it to Ticks AFTER you paste or opt + R ( repeat ) the click / clicks for sub division . If you set it to Ticks BEFORE you select area and hit opt + R it will then make you repeats of selection off by a sliver that is so small it is not measured by PT but is noticeable to the eye . It won't start falling off til about 1/2 way through a 4 min click set to 120 bpm but from there on it gets a little worse . Again , if you set it to ticks after the repeat there is no issue.
ps. Could someone please post a link to explain to me what the 48k tracking issue is ? I can't seem to find it but I've heard of few members bring it up briefly . Thanks
Old 02-22-2011, 02:56 AM
Tetsuo Tetsuo is offline
Default Re: Fade Bug . Has This been covered ?
Here's a lnk to the 48kHz issue
Originally Posted by DJ Hellfire
This weird midi issue: http://duc.avid.com/showthread.php?t=294462
And the bug that causes audio to be placed too early/late when tracking at 48kHz on 002/003 in 8.0.4 and above: http://duc.avid.com/showthread.php?t=284457
http://duc.avid.com/showthread.php?t...z+issue&page=2
Old 02-22-2011, 06:47 PM
Thanks !
[IMG] code is Off
plugs not covered by iLok ZDT musicman691 General Discussion 7 11-15-2012 07:47 AM
Error Message Not Covered in Answerbase: batchmister1 Pro Tools M-Powered (Win) 1 01-10-2006 08:53 AM
Probably been covered before BUT....Interfaces? Tricross Pro Tools M-Powered (Win) 0 11-03-2005 05:57 AM
MIDI-click....I know it´s been covered... go i huvet 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 6 02-20-2002 07:03 AM
regions gone when covered by another? pete scozzari Pro Tools TDM Systems (Mac) 5 08-24-2001 08:31 PM
