Old 12-26-2010, 05:05 PM
tonesponge tonesponge is offline
Default Problems bouncing down
I started having problems lately when I try to bounce mixes.
It basically alternates between saying that the processor held off interrupts too long, and that pro tools is interfering with other system tasks. The error windows that interrupt the bouncdown say to change the buffer size play back engine settings, but if I select 512, I get the interrupts message, and if I select 1024, I get the other one.
The first time it happened, I basically had to delete a bunch of busses and save my session as a a new session to make it start working right.
I kept my busses and so forth to a minimum after that, but I still run into problems even with just 12 or so stereo audio tracks and a couple of reverb busses.
Just removing busses does not clear the problem. I have to save, shut down, and reload to get it to work. Does that mean there might be a way to purge the cache or something like that and make it work, without having to delete busses?
Old 12-26-2010, 10:31 PM
aus scott aus scott is offline
Default Re: Problems bouncing down
What version of PT?
Are you using DVerb?
Scott
Old 12-27-2010, 05:48 AM
Pro Tools LE 6.1.1
Yes, I am using DVerb
Old 12-27-2010, 10:33 AM
6.1.1
Look for some updates(I would go to 6.4 with cs6 and cs9). There was a bounce issue with 6.something(sorry, its been too long) so you may have that. The mention of Dverb is alluding to the old denormalization problem that was solved by inserting a dither plugin, in front of the Dverb plugin(drag Dverb down one slot and add dither in slot 1).
Bouncing problems Rjkirk1 Pro Tools 9 1 09-09-2011 02:53 PM
Bouncing for CD problems Lowtone General Discussion 7 10-28-2009 05:41 PM
bouncing problems zebra_elements 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-21-2006 01:12 PM
Problems when Bouncing in LE 6.9 skinnyc 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 07-02-2005 11:57 AM
problems bouncing with PT4.2 izotropix Tips & Tricks 0 09-29-2000 10:29 AM
