Old 07-03-2010, 09:55 PM
Bodhisan Bodhisan is offline
Default Finger strumming acoustic and getting rumble/distortion
What's happening? When I use a pick (condensor, ribbon, dynamic mikes), no rumble or distortion. I use my finger to strum an acoustic, and it plays back like it's distorting or rumbling -- I'm not clipping. When I have the headphones on, it sounds fine. It's just on playback. Comments?
Old 07-04-2010, 01:27 AM
aus scott aus scott is offline
Default Re: Finger strumming acoustic and getting rumble/distortion
2 thoughts...
1. You're probably getting a lot more low freq when you finger-pick to when you flat pick. Could be the culprit - causing a compressor or limiter to really kick in...or something?
2. I had a similar problem and it turned out to be a rattle in the guitar itself. Which reminds me, I need to get that fixed.
Scott
Old 07-04-2010, 07:42 AM
Scott may be on to something there(braces can come unglued sometimes, but they can be fixed). Also, If the mic has a hi-pass filter, try it engaged. Try inserting am EQ plugin and engage the hi-pass to see if either helps. Maybe moving the mic to a position that yields a bit less bass?
How to best emulate guitar strumming? MR290378 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 7 12-31-2010 01:59 AM
AudioWarrior Kreator LE Acoustic Guitar Auto-Strumming Mschmid Virtual Instruments 0 07-06-2009 08:28 AM
Waves took care of the acoustic guitar low end rumble!! Jason from MaggieJack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 05-27-2001 07:45 AM
Strumming Fingers roykamen Pro Tools TDM Systems (Mac) 1 10-26-2000 06:39 AM
Acoustic guitar low rumble Jason from MaggieJack 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 9 10-08-2000 10:59 PM
