Old 05-19-2010, 02:08 AM
zef zef is offline
Default Structure Free - Sample Playback Truncate
Hi all,
I'm running PT M-Audio 8.01. I have one instrument track set up to play a bassline through structure free that came with PT.
The problem is, the bass line notes as programmed do not play to their required lengths. It seems like the note duration is truncated and terminates abruptly with a click. When I hit a note on midi-keyboard to play a sample from structure directly the same thing happens.
Any ideas?
Thanks
zef
Old 05-19-2010, 06:39 PM
Khatru Khatru is offline
Default Re: Structure Free - Sample Playback Truncate
Same here, except I'm runining 7.3.1. It happens with the moog taurus pedal patch from the Air Blog. It dies after 2.5 seconds. Bummer.
Didn't work for me for this issue, but trash your prefs and databases reboot and see if it corrects.
Dave
Old 05-19-2010, 08:13 PM
aus scott aus scott is offline
Trash the preferences file in the digidesign folder on your session drive - fixes it for a little while - then do it again when it happens again. Hey this is fun!
Scott
Old 05-20-2010, 05:02 PM
zef zef is offline
I did that and I'm pleased to say it did the trick for me! The bass notes now ring out their proper durations. Cheers guys
Structure 1.0 sample playback in PTHD 11.0.1 panamajack Virtual Instruments 1 08-31-2013 04:47 PM
Structure 1.1/Structure Free Sounds/Sample folder DTheone Virtual Instruments 9 03-29-2011 06:25 PM
Structure, revers Playback Sample ? daslicht Virtual Instruments 5 02-18-2011 05:34 PM
What note does the original sample map to in Structure Free? D_Japan Virtual Instruments 2 04-26-2010 01:49 PM
Harp Sample for Structure Free DonaldM Virtual Instruments 3 01-22-2010 07:12 PM
