Old 01-19-2010, 09:23 AM
BlueThursday BlueThursday is offline
Default Moving Pro Tools to another internal drive
Currently I have Pro Tools LE installed on the main hard drive (same as the OS, etc) with a second internal drive for all saved sessions, etc. I bought a second internal hard drive and would like to move applications to that drive and Pro Tools is the most used Program I have on the Mac Pro. I'm currently running 10.5.8 but have a SL disc.
I tried to install 8.0.3 using the full installer from my account but it didn't give me the option to install to another drive, the location tab just took me back a few steps and this cycle continued. Finally I gave up and just hit Install and it put 8.0.3 on the main drive.
Since I have a few additional plug-ins (purchased Massey, etc), has anyone experienced any problems with just uninstalling 8.0.3 and then reinstalling on the Applications drive? How does moving the plug-ins work? I haven't done this on a Mac before and don't want to mess anything up, the previous threads don't really address this particular issue.
Mac Pro - 8 core 2.8 GHz - 6GB RAM - 10.5.8
Pro Tools LE 8.0 - MPT2 - 003R
Old 01-19-2010, 10:21 AM
sunburst79 sunburst79 is offline
Default Re: Moving Pro Tools to another internal drive
Pro Tools (the application) needs to be installed to your operating system drive. Theres no need to move the actual program.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 01-19-2010, 11:43 AM
Why does it need to be on the same drive as the OS? Other programs don't need to be on the system drive to function.
Old 01-19-2010, 12:28 PM
Why do you need to move it?
Old 01-19-2010, 02:06 PM
Don't need to but want to, same reason why everyone else does it.
Old 01-19-2010, 07:36 PM
FajitaTone FajitaTone is offline
try using symbolic links to move the SW. google it.
Ray Trujillo
Freelance Audio Engineer
Old 01-20-2010, 01:24 AM
huzzam huzzam is offline
There should be no problem putting Pro Tools on any drive you like, but there's also no advantage to doing it, as Albee said. Loading the program & plug-ins requires so little disk activity, that you really needn't bother worrying about it. Unless you like timing the time PT takes to start up, and worrying about 5 seconds either way, or something. It won't affect performance of the program *at all*.
Sessions & audio & samples, however: yep put *those* on a separate drive for sure. 7200 rpm or more; firewire, esata, or internal is fine. (Firewire 400 gives you, not accounting for overhead, 173 mono tracks at 24bit/96kHz... Let's call it 140 with overhead. You really gonna use more than that?)
(& Who are all these "everybodys" that are "doing it?" Maybe they should start spending their time making music instead )
~peter in oakland
Old 01-20-2010, 03:08 AM
mindnoise mindnoise is offline
Just like to add:
As OS X is Unix you can put your stuff wherever you want as long as you link everything correctly.
It´s just the the Mac OS X Frontend don´t support it in a way to give you easy choices to screw up your system.
Obivously to keep everything simple for the average GUI-spoiled OS X user.
But it does not omit it.
The TERMINAL app and some knowledge of UNIX and you can arrange everything as you want it to be.
Just as about every second Linux user does.
best
last: PT11.3.1
Internal 5400 hard drive with Pro tools paulwilks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 8 05-24-2011 01:28 PM
moving pro tools media and project on drive to another willl3 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 11-18-2008 09:49 AM
Moving LE to new internal hard drive without install cd. BrettShumate 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-30-2008 06:06 PM
Moving part of Pro Tools to new external hard drive PSIII 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 05-17-2008 11:35 AM
OK to use a 120GB capacity internal IDE drive with Pro Tools? AlanB Pro Tools TDM Systems (Mac) 5 01-26-2002 05:45 PM
