Old 07-11-2001, 08:27 PM
polyorchid polyorchid is offline
Default SD2 interleaved and Jam
HAving problems with interleaved sd2 files burning in Jam. EIther have to convert in peak or rebounce as Aiff. Is this a bug or are other out there successful in burning SD2's with JAM?
G4/733
OS 9.1
PT 5.1
ATTO-EPCI DC
polyorchid
Old 07-11-2001, 10:44 PM
COCO COCO is offline
Default Re: SD2 interleaved and Jam
I have no problem with it, but my setup is configured differently.
Old 07-12-2001, 04:45 AM
Targon Targon is offline
I was gettin buffer underrun errors while attempting to burn interleaved files at 12x on my Plextor. I figured out my hard drive (Ext SCSI-2) was not streaming the data fast enuff to the burner. It occured to me that jam was reading both the left/right files at the same time requiring double the transfer rate. When i copied the same files to my internal ATA drive, it burned with no trouble.
The work around i found was to import the stereo file into Protools, let it split the file then export region definitions to the original stereo file. Then in Jam when adding tracks select regions an select the stereo file and burn. Not a prollem since.
Hope this helps
Targon
export MP3 interleaved Marvin the android macOS 4 02-01-2014 08:41 AM
Interleaved uses more resources? Frank Kruse Post - Surround - Video 15 07-15-2012 09:47 AM
OMF interleaved stereo aptmusic9 Post - Surround - Video 7 03-15-2012 12:04 AM
Can i stay interleaved? Nathan Schock 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 4 01-23-2008 04:20 PM
5.1 bouncing to interleaved .wav Evil Jack Post - Surround - Video 3 05-05-2005 11:15 AM
