Old 01-19-2005, 09:05 AM
bkremer bkremer is offline
Default Mic guitar cabs- XY or Near/Far? What do you use?
Post your thoughts. When you mic a guitar cab do you do XY or near/far or both? I have had a lot of success w/ near/far but a friend just turned me on to XY. Let's hear your ideas!
Old 01-20-2005, 02:20 AM
marknolan marknolan is offline
Default Re: Mic guitar cabs- XY or Near/Far? What do you use?
Hi There,
Last weekend I tracked some guitars and was happiest with using three mics!
- Shure KSM32 about 0.6 Meters (Approx. 2 Feet) infront of cab raised up a couple of inches or cm's
- Shure SM57 about 1 inch (2 cm) from Cone Straight
- Sennheiser MD421 as close as possible angled
Then i mix the signals together depending on my needs in the mix - but check out phasing when you place mics in different proximity!
Thats about it!
To make the sound as wide as possible i'll record the guitar line twice (or more...) and then pan the signals. When recording metal guitars or just guitars that need to be ultra tight and present in the mix i'll stand the cab infront of a wooden wall and place the mics the same way as mentioned above! Except I use a shure beta56...
thats all...
Mark
Don't be affraid of books! They are harmless if they are not read...
Two amps two cabs kittybite Eleven Rack 4 08-04-2012 12:35 AM
Phase setting for recording guitar though two cabs chris lee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 05-06-2006 04:29 PM
Phase setting for recording guitar though two cabs chris lee 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 05-06-2006 03:16 PM
Shifting Samples, Micing Guitar Cabs, Etc. Punx 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 2 10-04-2005 06:21 PM
Recording guitar cabs/combos NoviceDollars 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 15 01-19-2003 05:23 AM
