Old 05-21-2020, 06:10 PM
EddieJones's Avatar
Default Re: Pro Tools crashes with 20.5 EUCON enabled
Yes that might. The other thing to try for reference is to uninstall EuControl 20.5 and reinstall 20.1 and see if it works or not. The Control App wont connect but it would give us some data.
Old 05-21-2020, 06:26 PM
Juan Garcia Juan Garcia is offline
Hi Eddie,
Usb to ethernet for the iPad didn't make a difference. EUCON communication worked, but the problem when enabling EUCON didn't change.
Downgraded EUCON to 20.1 as you suggested. EUCON enablement completes successfully.
Learned the hard way to back up the iPad before upgrading to a new version /:
Now I'm working to revert to Avid Control 20.1 on the iPad. Would you happen to have at hand a v20.1 .IPA to manually revert the iPad app?
Thanks,
J.
Old 05-22-2020, 10:47 AM
EddieJones's Avatar
Checking in...are you still having this issue ?
Old 05-22-2020, 10:56 AM
Hi Eddie,
Issue is only with EUCON 20.5. Version 20.1 works well, but I cannot link with Avid Control because of the 20.5 update on my ipad.
Thanks,
J.
Nuendo 8 crashes EuCon blue moose Artist Series 1 08-12-2019 09:31 AM
Eucon crashes planck Avid Pro Mixing General Discussion 23 09-14-2018 09:20 AM
Avid Artist Mix not being recognized by any EUCON enabled application cgeorge@ut.edu Artist Series 3 09-25-2014 02:35 PM
eucon 3.0 crashes tandri79 Artist Series 7 06-24-2013 01:24 PM
FxPansion VST to RTAS Crashes PT 8.0.3 All the time if DSP Cache Enabled 25ghosts Pro Tools TDM Systems (Mac) 3 01-30-2010 08:36 AM
