  #41
Old 05-11-2010, 08:34 AM
BlueThursday BlueThursday is offline
Default Re: Pro Tools LE on new MacBook Pro I7
Same issue here, just got my MacBook Pro yesterday.
15" MBP i7 2.66
Always crashes (may not even load) when using the USB port closest to the power connection for my mbox2 but appears ok when using the USB port closest to the SD card slot. I haven't used it much but this is the initial observation.
Mac Pro - 8 core 2.8 GHz - 6GB RAM - 10.5.8
Pro Tools LE 8.0 - MPT2 - 003R
  #42
Old 05-11-2010, 10:22 AM
aggregatemusic aggregatemusic is offline
Angry Re: Pro Tools LE on new MacBook Pro I7
Mac Book Pro 15 with i7 processor...Leopard 10.6.3, PT LE 8.0.3
I can't even create a session without it freezing, let alone checking audio. Wonder how long I'm going to have to wait to get my Pro Tools back in working order...?
I'm going to have to check my install disks, but I ran software updater after getting his unit, standard practice, I thought. Sure screwed me this time. I'll likely have to erase the entire drive and start over with old system software. Sux!
  #43
Old 05-11-2010, 11:38 AM
tamasdragon tamasdragon is offline
Your machine is not qualified yet. Software updater is not standard, it is literally the worst. Always, always, and again, always combo updater and nothing else.
Hope this will soon sorted out.
my blog:Tamas Dragon
  #44
Old 05-11-2010, 01:32 PM
DigiTechSupt's Avatar
Which interface are you using? If it's a USB interface have you tried:
1. Using a different USB port
2. Unplugging your Ethernet cable (if one is connected) or
3. Toggling Bluetooth
Avid Audio Tech Support
Support FAQ
  #45
Old 05-11-2010, 11:27 PM
YouMeOh YouMeOh is offline
I'm on the new MacBook Pro, 15" i7 2.66 processor, with a Mbox Mini.
Changing the USB port did the trick for me!
  #46
Old 05-12-2010, 12:23 AM
These usb ports are playing with us users.
I have tried to measure the power of different usb ports on older, and newer machines, and have found that on older machines, it seems that the usb ports are less different capacity wise than on new machines.
Not really funny that we are heading to 8-12-16, etc. cores, and our hardware getting less and less reliable.
  #47
Old 05-12-2010, 03:16 PM
rockizoid rockizoid is offline
to those that got it working,, how's the performance on the new mac? are you impressed? if so, compared to what?
thanks
  #48
Old 05-16-2010, 02:49 AM
fins fins is offline
im having the same problem.
new macbook pro, core i7, 15"
10.6.3
mbox 2 mini
im using protools and logic and it wont work on either.
as soon as the mbox is plugged in it starts freezing and wont load.
i can play itunes through the mbox for a second before audio stops and computer starts to freeze.
dont want to use a powered usb hub as that would defeat the purpose of having a portable recording system.
  #49
Old 05-16-2010, 03:30 AM
imwaltraud imwaltraud is offline
10.6.3
mbox 2 mini
I am using my MBox Mini with an unpowered 4 port Logitech hub to which I also connected a wireless mouse, Ilok and midi interface......
So far everything seems to work ok.
  #50
Old 05-17-2010, 03:23 AM
Originally Posted by imwaltraud View Post
are you using the new mac pros? with core i7 processor version 10.6.3?
macbook air 2 gb ram-which pro tools ? ana23 macOS 2 07-10-2013 08:48 AM
Which MacBook Pro to get for P Tools. WernerF macOS 11 07-23-2012 04:55 PM
Pro Tools 8 and MacBook Air Moviesound Post - Surround - Video 3 08-23-2011 08:20 AM
Best way in to Pro Tools on MacBook fhrussell Pro Tools TDM Systems (Mac) 7 07-18-2010 05:59 PM
Pro Tools LE 7 with MacBook Dre aka Producer G Pro Tools M-Powered (Mac) 1 07-06-2006 05:02 PM
