Old 11-04-2009, 05:19 PM
mixaudio mixaudio is offline
Default iMac Core Duo or Quad Core?
I'm pretty excited about these new iMacs, but I'm wondering how much of a difference and improvement would be to go for the iMac Quad Core versus the Core Duo, considering:
a) that the Core Duo's speeds are higher, and
b) I've read in other posts that for best performance, users should set PT Playback Engine to use only 1 processor on Core Duos, which is half. Does that apply the same way for Quad Cores, taking advantage of 2 cores only?
Also, about converting FW800 to FW400 to hook-up my 002, I don't mind everything in the chain running at 400, but I'm more concerned about any potential issues with the 002 being connected to a "converted FW800 port". Any known issues?
Old 11-04-2009, 07:01 PM
nst7 nst7 is offline
Default Re: iMac Core Duo or Quad Core?
Definitely go for the quad core. Everything I've heard says it makes a big difference. Not only get the quad core, but spend the extra $200 to upgrade the processor to the I7. What you would do with the processors is use 3 for RTAS and leave one for the other stuff. That still gives you 2 more than what you'd have with a dual core.
As for the firewire, it works fine on my 003R to go from FW800 thru 3 800 hard drives, then 400 out to the 003R.
Old 11-04-2009, 08:54 PM
Dism Dism is offline
The "speed" of the processor really isn't all that important anymore. Most processors these days are in the realm of somewhere between 2.3 and 2.8GHz, which honestly doesn't represent a whole lot of change in terms of power. Doubling the cores, however, will result in an entirely new experience. A dual-core running at 2.8GHz won't even touch a quad running at 2.2GHz. Plus, as mentioned, you would be running 3 cores through PT rather than just one. This is why I tend to recommend people should drop their dual-cpu G5. Back in the day it was a great machine, but two single core processors can't even hold a candle to a single quad. Even if you slot up to the max 16GB of RAM, it can't compare at all to a single quad with 4GB of RAM.
I guarantee within the next year we're going to see a lot more computers with quads, including laptops. Mostly because Intel and AMD are going to be releasing 6 and 8 core single processors in 2010. Trust me when I say that you want more cores.
D
a n t h e I n c r e d i b l e S o u n d M a n
"Svetlana" v1 - 4.2GHz i7, 16GB RAM, OSX 10.7.4
Liquid Saffire 56 - PT10.2 - BFD2, VCC, Duende Native, Play 3.0
_C U R R E N T-D V E R B-S C O R E:515
Old 11-04-2009, 09:46 PM
Keybeeetsss's Avatar
Keybeeetsss Keybeeetsss is offline
Thatz Kinda like asking should u get a 4 or 8 cylinder(disregarding gas of course)...
MYSPACE ON'EIM
LAUTEN MICS & ME
DA'TUBE ON'EIM
'IS TAMARA HOME'
NO, SHE'S WITH
HOBO KEY
'' (that dopey green thing)
('we' must start using pronouns)
Old 11-04-2009, 10:25 PM
djkiller djkiller is offline
actually i this got me thinking.. i have a mac quadcore 2.6ghz fisrt gen. and i love it by the way :) couldn't see myself wanting much more..well maybe the 8 core but that's overkill. but can i upgrade it to the new chips? oh and it has two dual xeons
Old 11-04-2009, 11:31 PM
sunburst79 sunburst79 is offline
You want 4 cores. At least in PC land we found the Core 2 Quads doubled the performance of the Core 2 Duos.
Scott
Formerly Hobo Wan Kenobi
Core 2 Specs Page
ASUS P6T6 Revolution | i7 930 | 12GB OCZ DDR3 1600 7-7-7-20 | PTLE 10 | CPTK | 003 | Presonus D8 | 11Rack | Alesis AI3 | Presonus HP60 | Mercury + Studio Classics | Sound Toys | MasseyPack | Axiom61 | MAudio Keystation Pro 88
Old 11-05-2009, 12:34 AM
Not entirely sure if I follow what you're asking... but if you're asking if you can switch out the two dual xeons in your mac pro for two quad xeons the answer is no. The motherboard necessary for dual quads is completely different, in which case, you might as well buy a new Mac.
D
Old 11-05-2009, 12:37 AM
oh well i was just wondering. i'm pretty happy with my mac now and have 7gb of ram going to go up to 16gb. i'm barely taxing the system as it is... i can see it lasting me for awhile.
Old 11-05-2009, 12:44 AM
GW GW is offline
I'm running my 002 with my MacBook Pro via the FW 800 and haven´t had any problems sofar... [Regarding chaining see post above]
PT 12.4.0, iMac 27" Retina 4GHz i7, 32GB RAM, PoCo x8,
Digi002 Fact., Logic X|FCPX|Motion
Plugins: Waves Diam. V9|Artist Sign Ser.|SSL|GTR3.5, TC MD3|Harm4|VSS3|DVR2|Nonlin|Unwrap, Sonnox Infl|Dyn, Autotune
VI: Reason 8, Ivory It., Trilian|Omnisphere, VG2/RealGuitar, Kontakt6|GPO, Goliath|Gypsy|Fab Four, Candy, Structure, EZdrum, BIAB Audiophile
Hardware: TLM49|TLM103, SPL Track One, TC M-One, Artist Contr.v2|Transp|3xMix
Old 11-05-2009, 09:52 AM
This is a misconception. By setting the Playback engine to use one less than the total number of processor cores does not necessarily mean the one excluded processor core is not being used. It simply means that it is free to handle the non-realtime plugins that may be in your system. When you dedicate all your processor cores to only handle realtime plugins, and you have a non-realtime plugin installed, the system has no resources left over to handle them. In fact, if you have many non-realtime plugins, that one excluded processor core may actually be doing more work than the other dedicated processors. It is a balancing act. In the future, Avid will release a new RTAS engine that should dynamically handle both realtime and non-realtime plugins. Don't think that you are "not using" the processor core for plugins. Think that you are "making it free" to handle other (non-realtime) plugins. There is no list available of realtime vs. non-realtime plugins at this time so you don't know which is which.
Obsidian Dragon
Mac Studio M1Max - 64GB
2011 quad-core iMac with PT9 and Mbox 3? soundwrks macOS 2 09-17-2011 11:09 AM
New iMac Quad Core bradch00 Pro Tools M-Powered (Mac) 0 03-02-2010 11:51 PM
Quad core imac i5 + Mbox 2 Pro (or digi 002) VS. Pro tools Mix & 888/24 kristiger 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 0 02-24-2010 07:26 AM
iMac Quad Core i5 vs i7 Dave D 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 6 11-11-2009 10:50 AM
IMAC or PC Quad Core Mycolorizred Pro Tools M-Powered (Mac) 21 09-10-2009 09:11 PM
