PT Crashes Immediately on Launch
PT quits immediately on launching. Checked iLok, re-installed PT 2018, upgraded to 2020, trashed preferences. Nothing works. Began after an unnoticed screen recording filled up my main drive. Deleted the big screen-record video file. I even wiped the drive and started over from Time Machine. Everything works fine...except Pro Tools. This is an new iMac bought in April. Pro Tools has worked perfectly on it until this incident. Using PT to work from home. With Fox Television Stations. Any advice appreciated.
Re: PT Crashes Immediately on Launch
Hi, So you definitely uninstalled everything and trashed all the prefs before a fresh install? definitely any old or out of date plugins left over were all trashed before installing? repair disk permissions after trashing prefs and reinstalling? What OS? Chris
I did not uninstall plugins. I guess I should do all that before going forward. I installed Pro Tools First this morning, just to see if that would work. It didn't. Same exact issue. Something in there is stopping this launch right in its tracks.
Will try the full uninstall. Thanks! |
Two things you need to check.
First of all you mentioned Time Machine, which is not a good idea. Do a clean install and copy stuff manually. That is the way to go. Second thing, you mentioned new hardware. Have you checked the compatibility info, are you on supported OS or upgraded to latest?
EUCON 3.7 crashes immediately!!!!! | PT user | Avid S1, S3, Dock and Control App | 50 | 11-04-2017 09:54 AM |
EuControl 3.7 crashes immediately with PT | moranibus | Avid S1, S3, Dock and Control App | 11 | 10-19-2017 08:52 AM |
Pro Tools crashes immediately | Rich Crescenti | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 09-21-2010 03:44 PM |
PT8 M-Powered Crashes Immediately | chrisconover | Pro Tools M-Powered (Mac) | 10 | 05-31-2009 10:19 PM |
Mac G4 Crashes Immediately...I'm really new to this | luapfitz | Pro Tools TDM Systems (Mac) | 2 | 09-04-2000 05:40 AM |
