NI Maschine Studio Not recording Midi to Pro Tools 12 as a plugin
I hope I'm posting in the right forum. I'm trying to use Maschine Studio as a plugin in Pro Tools 12.8.0 running Windows 10. When I press the pads I hear sound however midi notes do not appear in pro tools. I am able to trigger Maschine sounds and record with my M-Audio midi keyboard but not the Maschine. I tried placing maschine in controller mode but that didn't work. I also went into the maschine settings and chose host for midi, and turned midi on. In Pro tools under instruments on the instrument track Maschine is inserted on, Maschine is greyed out with a message saying "N/A because possible feedback loop detected" I did try to manually map the maschine in midi studio and I even added midi cables to my digi 003 in case for some reason midi wasn't transported via USB. This did not work. Of course in the NI forums I'm hearing this is a Pro Tools issue since it works as a plugin in other DAWs. I'm not sure if it is or isn't but I'm hoping someone may have a fix over here. |
Re: NI Maschine Studio Not recording Midi to Pro Tools 12 as a plugin
Sounds like maybe you should try the idea of instantiating Maschine on an aux track and make a midi track, which has Maschine asigned as an output, to trigger Maschine. Might work, might not.
There is a workaround though and you nearly found it! Maschine needs to be in controller mode but Pro Tools won't record it's output unless you go to Setup>MIDI>MIDI Input Enable in PT and turn Maschine Virtual Input on, (it defaults to off.) Then hit the Group C button on Maschine in controller mode which should select the correct octave. It's a bit clunky and you lose the pad colours but it does work. Maschine really needs a "Local Control Off" mode like most hardware synths so you can use it as a standalone sound module and sequence in Pro Tools without switching to controller mode. I asked them about it but they weren't interested.
Dave Marsden UK Last edited by Marsdy; 07-25-2017 at 10:12 AM. |
Hi there i have the exact problem like yours have you managed to fix this problem because i am sinking ????
Recording Alesis DM10 Studio Kit With Plugin | SeventhSounding | Virtual Instruments | 11 | 09-22-2016 07:54 PM |
Maschine Studio MK2 | Tops3b | Buy & Sell | 0 | 05-06-2016 02:26 PM |
MPC Studio for sale or Trade Maschine MK2 | john1192 | Buy & Sell | 0 | 11-15-2015 06:35 PM |
NI Maschine 2.0 Listed as Unauthorized plugin in Pro Tools 10 | hellojoshgraham | AAX Plug-ins | 2 | 05-28-2014 04:38 AM |
Maschine STUDIO dose not appear in Instrument plugin in Pro Tools 10 | MikeX2 | Pro Tools 10 | 2 | 03-17-2014 06:23 AM |
