Re: Much slower offline bounce in 2019 vs 2018?
Updated all of my plugins, everything should be up to date. Occasionally I'll get normal speeds, but then it dips ridiculously low. I'm getting speeds like 13x when it used to be consistently above 100-120x, even with other apps opened like Chrome and whatever else I wanted.
ill always get 1.5.. or worse..12core 2013mac 64gigs of ram.. clean install in june SSD all around. UA slows stuff down in general..
perhaps its izotope oz8.. is just Bee Esss. this should be pretty fast comp.. but Ive spent a childhoods worth of time wrestling this type of stuff and .. well we do need to make some ..Muuuusics at some point
Hal Cragin On the DUC Since The Year 2000 AD Ventura ,PT 2022.10, MacbookPro 13"[2020] M1 16G, Antelope Orion 32+ Gen3..SSL Sigma summing, SMART Comp C1LA, CharterOak EQP-1 Oceanway Audio HR4S monitors . SSL X-Rack w XR618 compressors, dbx 160x [2] |
Deactivated as in not instantiated in a session or removed from your plugin folder on your HD? Two quite different things. Sent from my iPhone using Tapatalk |
That’s the thing. Some plugins will severely slow down your bounce times. Basically, the more CPU a plugin consumes, the slower the bounce time. I can get close to 70-80x bounce speed on a lot of sessions. If I put ONE instance of Soothe in that session with oversampling turned on, it will slow down to 6-8x when doing an offline bounce. The OP’s issue may not be plugins and something else, but it’s definitely the first place to look. Disk issues could be another. Heck even faulty RAM could cause weird issues. It’s all well and good to see ‘all I did was update Pro Tools’ but unfortunately, and I’ve seen this happen MANY times, other things have happened at the same time that could cause issues. Computers are extremely complex things. Sent from my iPhone using Tapatalk |
i mean clicking "deactivate" which has always cleared their cpu suckage and increased bounce speed in the past, before this problem
#16
Deactivating a plugin means the plug is greyed out on mix window. Removing plugin from the system means moving the plugin file to unused folder so PT won't load it to begin with.
Updating 2018.2 to 2019.5 | bektolio | Pro Tools 2019 | 15 | 05-11-2019 02:40 AM |
Compatibility between 2018 and 2019? | beatlogik | Pro Tools 2019 | 2 | 05-09-2019 01:51 PM |
Bounce to disk offline error on 2018.4! take care, use online instead! | tamtamstudio | Pro Tools 2018 | 25 | 08-19-2018 02:36 PM |
Offline bounce crash, probably Waves-related, and offline bounce not 100% correct | Skwaidu | Pro Tools HDX & HD Native Systems (Mac) | 3 | 03-23-2015 03:55 PM |
