Latency/Buffer/External HD
How do I change Latency/Buffer in Windows 7 without shutting down SE?
Also where is the function to assign my external Hard drive to record session audio files? Thanks |
Re: Latency/Buffer/External HD
SE uses a simplified set of controls. In Preferences, you can select either "Recording or Performing" or "Mixing or Producing". This determines the values for latency, buffer size, etc. You cannot adjust these values directly.
In Pro Tools SE, all audio files, etc are saved in the session folder. When you first create a session, save it your external hard drive. If you would like to move an existing session, use File > Save a Copy In... This will duplicate the session on your external hard drive.
Product Designer Avid |
Low-Latency Input Buffer | zion | Pro Tools 11 | 109 | 09-13-2015 04:46 PM |
HW buffer size and latency | JPeters86 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 10-07-2007 11:22 AM |
Latency and Buffer Question | jimst57 | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 03-27-2007 06:47 AM |
latency/ buffer overflow..Please someone help me | ozzymau | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 12 | 02-01-2005 02:52 AM |
Latency/HW Buffer Question | vlad | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 7 | 06-03-2003 10:14 AM |
