#31
Re: 25% CPU usage increase on input monitoring
Ok - I tried that out (substituting Aux tracks for Audio tracks with input monitoring engaged) and ended up getting the exact same results. So it's not exclusive to Aux tracks! Interesting.
clancychris, I think this would help explain the similar behavior regarding your situation. |
#32
On a 2010 8 Core Mac Pro 2.4 with 32 gig ram: Test 1: I can run one instance of signal gen and 6 instances of Pitch II on each audio track before hitting instability. (total of 420 Pitch II's and 68 Signal Gen) Test 2: I can run one instance of signal gen on each of the 68 audio tracks, and then 39 instances of Pitch II and then it goes nuts. - note: i enabled them in rows. So that's a fair difference and explains why I'm having issues |
#33
I think your issues are related to the dual buffer. I can't think of any other reason there would be such a big difference in CPU between running plugins on a track vs a aux. I'm wondering if this is also part of what causes the infamous 9173s that we've been plagued with since 11 was introduced?
2022.12, OS 13, M1Max, 64gig of ram, Samsung t7 and T5 external drives, Apollo 16mkII, Apollo Twin MkII |
#34
#35
Did a little looking into the dual buffer feature. I agree that it's possible that it could be tied to this issue somehow, but it baffles me why on earth you'd want the lowest possible latency (coupled with the highest CPU usage) to occur on anything - audio track, aux track or otherwise - that isn't being fed a live input. Then again if we're looking at this to be the cause, it would only moderately increase the amount of power needed from the CPU, which doesn't really explain the unstable spiking behavior. |
#36
Open a session and take note of your CPU usage. Then put a hardware insert on the Master Bus. Anything will do, if you don't have hardware just make it anyway and try it. My CPU usage falls by 20%+ instantly. Just by putting the insert there |
#37
#38
I found a way to try that here with another interface (insert at the end of the chain). Results still remain unchanged though. I had high hopes for that idea too, given my past experience.
#39
I'm in the same boat over here. My mix sessions are set to 1024 buffer and when my print track is in input, session jumps about 25%-30%. Sometimes cripples the whole session.
Lior HD Native * PT 2018.12 * OS X 10.13.6 * MacPro 12 Core * 2.4GHz 24GB Ram * 2XUAD2 Octo * Waves Platinum * Lexicon PCM Native Bundle * Sound Toys Bundle* AutoTune8 * NI Komplete11 * BFD3 * Synthogy Ivory II* Vienna Ensemble Pro * Spectrasonics * Slate trigger2 *xFer records * Softube * Vienna Ensemble * DMG Expurgate * Massey DRT2 * iPad Air/Avid control * EuCon 18.3.0.217 * |
#40
Yeah also tried it. In this situation it makes no difference to it
Crazy High CPU usage when enabling input monitoring | BCnSTL | Windows | 6 | 07-01-2016 03:23 PM |
CPU usage increase with 11.1.2? | jcoppage | macOS | 0 | 02-16-2014 05:41 PM |
CPU usage increase with upgrade to Leopard and PT8? | plangentmusic | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 0 | 07-20-2009 10:19 AM |
increase the CPU Usage Limit in the Playback Engin | rosebartu | Pro Tools M-Powered (Mac) | 4 | 10-16-2006 08:11 AM |
Increase CPU Usage - How? | ladyvidora | Pro Tools TDM Systems (Mac) | 3 | 08-17-2004 09:25 AM |
