Old 08-18-2020, 08:25 PM
lokimojo lokimojo is offline
Default Having installl issues in PC
I've recently switched from Mac to PC and am having a terrible time of trying to install my PT12 onto my PC.
As it starts installing I get an error message saying "The installation of Microsoft Visual C++ 2013 Redistributable Package (x86) appears to have failed. Do you want to continue the installation?"
If I click continue and try to open PT after installation, I get an error saying "Assertion in ..\ .. \ Sys\ Win32\Sys_FileLocUtilsWin32.cpp", line 344"
I've tried installing some older Visual C++ "updates" but that hasn't helped.
Can anyone offer any advice or sollutions? I would be eternally grateful.
AMD Ryzen 5 2600
16GB RAM
Windows 10 (64-bit)
Old 08-19-2020, 08:37 AM
The Weed's Avatar
The Weed The Weed is offline
Default Re: Having installl issues in PC
You may have a corrupt installer. Download it again from your Avid Account, do not use Avid Link. Remove all instances of the previous install and use CCleaner to "clean" your Registry. Back up when asked and run CCleaner until it doesn't show anything more to remove.
Reboot the computer. Use a backup program like Acronis or Macrium to make an image of your OS drive. I do this before any update/upgrade/uninstall/install so that I can get back to a clean, working system in case there are issues, like you ran into.
Install Pro Tools again using the new installer and be sure to Right Click it and Run As Administrator.
HTH
Demos: brucehayward dot com
SonoBus
Source-Connect: brucehayward
Options for Remote Direction
Old 08-19-2020, 08:56 AM
The Weed's Avatar
BTW, what interface are you using? It needs a proper ASIO driver installed, preferably before you install Pro Tools.
Also your record drive needs to be Formatted NTFS and be Basic, not Dynamic.
SonoBus
Mbox Gain Issues and Protools Issues (Bounce to Disk and Knob/Pot adjustments) Lucky Bastard Getting Started 6 01-16-2014 03:29 PM
No sound - asio driver issues - NTFS issues mitchelljrickey Windows 0 06-21-2012 05:35 PM
ProTools 9.0.5, iLok issues, Digi 003R+ issues zachbot Pro Tools 9 6 10-12-2011 08:19 PM
8.0.4 Issues (Quick Punch & Mute/Solo issues) pauledwards 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 1 10-06-2010 09:35 AM
my computer cant seem to installl my hardware drivers properly djcalg 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 4 06-20-2010 01:08 PM
