Stuck in PIO mode.
I was just doing some more trying to get the errors to stop and I
saw that I am in PIO mode even though I have selected DMA if avail Win XP. I know I saw a post about this but can't find it. Actually I can never find anything with the 'search'. I know I am probably using it wrong. I tried the suggestions on digi, no help. Can anyone help? sg |
Re: Stuck in PIO mode.
Cavell Studios |
Hi!
I just had this problem. If you try looking up this registry entry using regedit (don't try this if you've never used regedit before) [HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Contro l\Class\{4D36E96A-E325-11CE-BFC1-08002BE10318}\0001] and \0002 These are usually the entries where Win indentified the drives for Primary IDE1 master and slave. If you modify the values for: "MasterIdDataCheckSum" and "SlaveIdDataCheckSum" and clear the value data it will force windows to reidentify the drive after reboot. Cheers, // J
Digi 002 Mbox 1 Digi001 (retired to shelf) Asus P5K Premium v3, Q6600, 2x2GB Corsair Tyan Thunder n3600B (S2927A2NRF) 2xAMD OPTERON 2214 2.2GHZ Win XP Pro SP3 |
Strike stuck in kit mode | digijohn | Virtual Instruments | 6 | 06-28-2010 10:48 AM |
7.1 Gets Stuck in Scrub Mode | deanguidry | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 0 | 03-12-2008 09:54 AM |
Protools stuck in scrub mode | studiostrat | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 2 | 06-07-2007 06:32 PM |
DIGI 002 stuck in standby mode! | BillyP | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 3 | 12-26-2006 08:11 PM |
USD is stuck in Generate Mode!!!! Help!!! | pnoise | Pro Tools TDM Systems (Mac) | 2 | 09-17-2002 01:28 PM |
