Go Back   Avid Pro Audio Community > Legacy Products > RTAS & TDM Plug-ins
Old 09-01-2014, 05:18 PM
YYR123's Avatar
YYR123 YYR123 is offline
Default Slate FG-X CPU usage off the chart.
I have a session I am leveling out and EQ'n the 2-Track (read homespun mstr) and I am using 1 audio track stereo and 2 Aux tracks stereo.....
8 plugs in the entire session recorded at 96khz
CPU usage is 9% until i activate my FG-X on the premaster....then I jump to 40% CPU and I start getting -6101 errors.....
How is this worked around?
Daniel
Old 09-01-2014, 06:10 PM
YYR123's Avatar
Default Re: Slate FG-X CPU usage off the chart.
And the -9128
Daniel
Old 09-02-2014, 05:17 PM
Is your buffer set as high as it will go?
Old 09-02-2014, 05:31 PM
YYR123's Avatar
Yep 2048 but it doesn't change the CPU percent...
Daniel
Old 06-05-2017, 03:25 PM
petermmurray petermmurray is offline
Did you ever figure out a solution for this? I'm having the same problem on a mix with that
Old 06-05-2017, 03:55 PM
YYR123's Avatar
Nope and I can't believe this thread is almost 3 years old and Slate still hasn't updated that code.
He had said he would release another plugin until he had released FGX2......
Utterly ludicrous
Daniel
Old 06-06-2017, 07:20 AM
Southsidemusic's Avatar
Utterly ludicrous
He said "He would NOT release another plugin" until FGX-2 was finished ....
Best Regards
Christopher
#thestruggleisreal
South Side Music Group
WEBHOME
Old 06-06-2017, 08:47 AM
YYR123's Avatar
Danke, Tack....
You are correct he would Not.
Since then he released
VMS
Raven 2.0
His new interface
All of the new plugs with the subscription model.
Thanks user SPA, you sure told the truth there.
Daniel
Old 07-31-2017, 07:29 AM
WernerF WernerF is offline
The buck rules the day here. He will always use that approach and fudging the truth to his users's is just a part of the necessity of applying this method to business dealings. At least we've got his number.
FS: Slate VCC, Slate VTM, Soundtoys Radiator apesong Buy & Sell 10 05-01-2014 03:01 PM
Slate Digital and Steven Slate Drums AAX DHL AAX Plug-ins 6 04-22-2013 12:50 PM
CPU Chart...might help/ 685 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 0 08-29-2009 04:29 PM
is there a chart on the dif between LE and HD? Filmusic Pro Tools TDM Systems (Win) 0 09-30-2008 09:21 PM
Native Plug-in CPU Usage "comparison chart"...? kirkbross 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 1 01-14-2008 08:48 PM
