Old 04-25-2017, 01:40 PM
Raoul23 Raoul23 is offline
Default How to make a rise
Hi guys I'm after making a rise before a chorus in a song, kind of what they use in EDM. Can anyone help me do this the quickest and easiest way please
A big thank you in advance
Raoul Crane
www.blaze-studios.co.uk
PT 10.3.10 HD Accel 6, Mac Pro 3.1 Dual Boot Lion 10.7.5 and Maverick 10.9.5 32GB Ram Magma PE6R4i Chassis
Old 04-25-2017, 02:43 PM
Ben Jenssen's Avatar
Default Re: How to make a rise
Can you be more specific?
A rise?
In level, or what?
Old 04-25-2017, 02:46 PM
It's a bit like a reverse symbol sound but slightly different and the noise/sound becomes more hi pitched like a HPF is being sweeped from one end to the other hope this helps more
Raoul Crane
Old 04-25-2017, 02:52 PM
edwinstar's Avatar
edwinstar edwinstar is offline
use the signal generator to create white noise and then automate a eq lopass sweep.
or
http://www.airmusictech.com/product/...r#.WP_EcYHKGEc
Old 04-25-2017, 03:11 PM
or
Yes that's one thank you
Raoul Crane
Old 04-26-2017, 03:02 AM
simon.a.billington simon.a.billington is offline
You can add a bit of resonance to the low pass as well and possibly automate the volume for more dramatic effect. You could do the same effect with a synth too.
Old 04-26-2017, 03:27 AM
I have Access Virus TDM synth, how would i go about doing it with this, i'm not a synth person so would be learning from scratch.
Raoul Crane
Old 04-26-2017, 03:37 AM
Similar technique to above, but use the synth oscillator to create a white noise signal, if possible. Then use the inbuilt Low Pass Filter and resonance to shape the tone.
Start with a low frequency setting on the LPF and raise it to a higher value using automation. You can set up the volume envelope attack to be a little bit slower too, so it doesn't sound so abrupt.
In all reality there may be a riser or sweep patch In the Virus. See if you can find one before messing about with doing your own.
Old 04-26-2017, 03:39 AM
Stig Eliassen's Avatar
- use a keyboard sound that fades out > print it > reverse it
- automate the pitch bend (+/- 12 semitones) on a synth
- reverse a cymbal
- automate filters/EQ of pure pink noise with FX (reverb/delay/modulation)
There's a million ways to do this.
Old 04-26-2017, 03:46 AM
- reverse a cymbal
Thank you, ive tried the reverse cymbal one before but never seemed to get it to sound/sit right in the mix can sometimes sound a bit harsh. Its the noise rise that i'm after i will try these tonight and report back. Thank you for your help
Raoul Crane
Bass Rise? domdompompom Pro Tools 12 1 10-27-2016 03:16 AM
FS: Slate Digital plugins - NI Rise and Hit PeterKorcek Buy & Sell 5 01-23-2016 08:46 AM
WOW this is the Coolest Ever!!! Roli Rise Southsidemusic General Discussion 3 12-20-2015 06:18 AM
Dramatic pitch rise effect - how to?? phillyt2k Pro Tools 10 9 04-28-2013 11:35 AM
CPU and System Levels rise after vocals end... Target Earth Ent 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 12 01-08-2002 12:54 AM
