Old 04-18-2016, 04:49 PM
Karel Noon Karel Noon is offline
Default D-Verb Mono and 1in2 not sharing DSP on s3l-x?
Is it correct that the DVerb mono and DVerb 1in 2out will not share a DSP?
If that is the case is there any chance of an update?
Or is there finally another good reverb for the S3L-X that is low on DSP?
Old 04-26-2016, 12:24 PM
RyanJ's Avatar
RyanJ RyanJ is offline
Default Re: D-Verb Mono and 1in2 not sharing DSP on s3l-x?
By design most reverb plugins use a hefty amount of onboard memory, and subsequently can't share most of the time.
This unfortunately also means that an instance of stereo, 1 in - 2 out and an instance of mono are considered different plugin types.
Almost all reverb plugins will be pretty heavy on DSP, but if you're going to go heavy, I would highly recommend checking out the sonnox verb, that thing is ridiculously tasty. I know that's not the solution you were hoping for, so as I continue to pursue heavily getting developers onto the live sound platform, I will absolutely keep that in mind.
Ryan John
Principal Product Manager | Avid Live Sound
ryan.john@avid.com
Old 04-26-2016, 03:26 PM
Yeah, not 100% what I was looking for, because you can run so many instances of dverb I have it patched to some Chanel's and I only need one extra as send/return. It is a big waste of DSP putting one dverb on one....
But maybe we will get the other DSP for us to use?
Old 04-27-2016, 09:43 AM
RyanJ's Avatar
Im hoping so! But also don't forget 96k without dropping channel count would require more DSP processing also!
Ryan John
ryan.john@avid.com
Old 04-27-2016, 10:49 AM
I Really don't care about 96k I hope it will be an option and not a fixed feature.
I would rather go for more busses and more DSP for FX
Old 04-27-2016, 11:24 AM
HLD HLD is offline
I am with Karel on this. Rather busses or fx. Or best, a choice between them.
Old 04-27-2016, 11:55 AM
RyanJ's Avatar
I totally understand that, I also understand customers wanting to run shared io between S3L and S6L which would mean matching sample rate between the two systems.
Both are totally valid, and important workflows, and I would love to support both.
Ryan John
ryan.john@avid.com
Old 04-28-2016, 12:17 AM
Amplitude Amplitude is offline
Reading between the lines, I think I got my answer there ;-)
making mono track into stereo or double mono in PT7LE VeganMuso 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) 9 02-02-2012 05:36 AM
A question about mono/stereo plug ins on mono tracks. rockguitarist1255 Pro Tools 10 2 12-24-2011 07:33 PM
one mono audio file when two mono tracks recorded bluerej Pro Tools M-Powered (Win) 0 02-06-2010 01:09 AM
Need a killer vocal verb setting for D-Verb tmoc-rocks 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) 5 02-21-2005 08:51 AM
Stereo vs. Mono D-Verb John Link General Discussion 3 05-29-2002 05:53 AM
