Old 02-12-2016, 01:12 AM
Amplitude Amplitude is offline
Default S6l&s3l
Is there any status on, when we can use S6L and S3L in an shared Stagebox environment?
Markus
Old 02-18-2016, 09:44 AM
RyanJ's Avatar
RyanJ RyanJ is offline
Default Re: S6L&S3L
There are a LOT of steps that need to be taken to get both systems running smoothly together, and even once that's done, there is a long period of testing to ensure that it's a stable system.
I can't tell you when it would be finished, but I can tell you that the team is working extremely hard to reach goals like this.
Ryan John
Principal Product Manager | Avid Live Sound
ryan.john@avid.com
Old 02-21-2016, 12:46 PM
Mike496's Avatar
Mike496 Mike496 is offline
Default Re: S6l&s3l
That is very interesting news! With S6L running at a sample rate of 96k and S3L running at 48k, does this imply S3L may get a bump to 96K or will S6L have to come down to 48K?
Old 02-21-2016, 11:30 PM
Karel Noon Karel Noon is offline
Default Re: S6l&s3l
I am not 100% sure, but from what I have seen while experimenting with AVB it looks like all S3L hardware is 96k compatible. So it is probably just a software update....
Old 02-22-2016, 12:16 AM
Default Re: S6l&s3l
isnt the s3 with Eucon 3.3.2 already 96k enabled? but anyway, the sample rate might not be the biggest problem ;-)
Old 02-22-2016, 01:41 AM
Default Re: S6l&s3l
I haven't tried that, but I am sure that the Stage 16 are 96k, so all in all it should be possible.
I also think that when you connect both systems it might be possible to get audio from one system to another already, but only in an experimental environment, not road ready
