mixed bit depths
I notice that pro tools can now play back AIF and WAV files natively in the same session. Cool.
Why is it then that files must be converted from 16bit to import into a 24 bit session. Surely if the CPU can swap the bytes around between big-endian/AIF and little-endian/WAV then it can also add 8 binary zeros to the end of each sample to playback 16bit files in a 24 bit session? |
Multiple bit depths in same AAF/OMF | colinato | Post - Surround - Video | 1 | 09-28-2010 08:33 AM |
different sample rates and bit depths | Andres Gonzalez | Tips & Tricks | 4 | 10-23-2006 06:13 AM |
What is a good resource on bit depths? | Dale-c | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Mac) | 12 | 01-15-2004 12:53 PM |
SSC Bit Depths | nozza1 | Digidesign Hardware & Software | 0 | 06-15-2001 02:55 PM |
Multiple bit depths in PT: WHEN?? | John McDaniel | Tips & Tricks | 7 | 01-31-2001 09:29 AM |
