Help! The attacks of the midi notes disappear when I quantize
Hey guyz, i don't know if anyone else has had this problem.
Say I record a midi performance on and instrument track using a virtual instrument ( kontakt ). When i quantize the notes, the attacks are almost inaudible. When I undo the quantize i can hear the notes clearly again. Same applies with midi input quantize. Any thoughts? Thanks! |
Re: Help! The attacks of the midi notes disappear when I quantize
A lot of it depends on the patch, for example, typically with a classic Moog patch, when notes overlap the filter won't retrigger which could make it sound like you've lost note attacks. When you quantize, use the MIDI Operations Grid/Groove Quantize window and check to see that the "Preserve note duration" box is checked. That should help.
MIDI Quantize - only attacks are left | boove | MIDI | 5 | 02-17-2009 05:43 PM |
Midi Notes disappear | akumraza | MIDI | 9 | 11-11-2008 05:48 AM |
Midi notes disappear | neeel | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 83 | 12-15-2007 01:20 PM |
Midi Notes Disappear? | RokVox | MIDI | 1 | 08-11-2007 10:12 AM |
MIDI notes in 7.0 disappear... | scottedog | 003, Mbox 2, Digi 002, original Mbox, Digi 001 (Win) | 7 | 11-17-2005 09:37 PM |
